TommyC Posted November 8, 2024 Share Posted November 8, 2024 I’ve got an almost new 4s battery that has puffed up on one cell. I’m thinking I can turn it in to a 3s but I’ve never soldered directly onto lipos before. Am I right in thinking you need some kind of special solder and/or flux to be able to this? I’m fairly confident with soldering, but perhaps not that quick. Do I need to worry about putting too much heat into the lipo? Should I discharge to 3.0v? Quote Link to comment Share on other sites More sharing options...
wombat Posted November 8, 2024 Share Posted November 8, 2024 Bearing in mind that you would also have to solder on a 3s balance lead, and wondering about the state of the remaining 3 cells i would err on the side of caution and dispose of it. If its almost new could you claim on warranty ? Quote Link to comment Share on other sites More sharing options...
TommyC Posted November 8, 2024 Author Share Posted November 8, 2024 Corally would not honour the warranty, as its over 30 days since purchase but thankfully modelsport were good and are sending me a replacement. Just seems a waste to chuck this when it’s only had 2-3 cycles. Was thinking I can just remove the extra balance lead but leave the 4 pin plug on. My charger will still only recognise it as 3s. It’s also capable of showing me resistance when charging so I can check it’s all good when I charge it. I can then 3d print a new case for it. 1 Quote Link to comment Share on other sites More sharing options...
locky Posted November 8, 2024 Share Posted November 8, 2024 I've removed a dead cell from a 4s and use it as 3s. Just used normal solder and cover exposed connections to prevent shorts. 1 Quote Link to comment Share on other sites More sharing options...
TommyC Posted November 9, 2024 Author Share Posted November 9, 2024 (edited) Well the lipo is now in a bucket of salt water in the garden! I got it apart just fine but as usual I made it more complicated than it needed to be. I wanted to flip the new negative tab over and solder to the other side of it. It doesn’t work. A little more research told me I need aluminium specific liquid flux. Unfortunately I got the tab a bit hot and it started to melt the glue a little around the edge of the lipo so I’m not taking the risk. Good practice for next time though. Edited November 9, 2024 by TommyC 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted November 9, 2024 Share Posted November 9, 2024 I can solder and do it reasonably well but i wouldnt attempt what you did mate Quote Link to comment Share on other sites More sharing options...
