wolfie1 Posted November 3, 2024 Posted November 3, 2024 (edited) I quite fancy 1 of these, but i would want to change the power system and sell the bl2s system before i run it as i dont think it would be powerful enough for me and i dont have any 2s lipo and instead of investing in a couple i would be as well upgrading the power system, i have been looking at hobbywing systems but have no idea what i would need i was looking at this but would it be a good match? https://www.modelsport.co.uk/product/hobbywing-combo-max10-g2-140a-esc-3665sd-3200kv-g3-motor-1350919 some advice on this would be greatly appreciated I did consider the corally syncro as i like the look but aftermarket hop ups doesnt seem to really exist for it looking online and i dont really like the look of the arrma buggy and the notorious breaks pretty much every time i have it out so that is also making me shy away from another arrma product Edited November 3, 2024 by wolfie1 Quote
Kpowell911 Posted November 3, 2024 Posted November 3, 2024 (edited) Why not just buy the VXL 4S version? Traxxas are very sneaky when it comes to there VXL and ‘normal’ versions. They look identical other than the power systems but the VXL has a lot more alloy parts (hexes, brace etc) over the regular one Edited November 3, 2024 by Kpowell911 1 Quote
wolfie1 Posted November 3, 2024 Author Posted November 3, 2024 (edited) 5 minutes ago, Kpowell911 said: Why not just buy the VXL 4S version? A number of reasons, i like the look of the other better 1 and it wont be for sale for Christmas Edited November 3, 2024 by wolfie1 Quote
Kpowell911 Posted November 3, 2024 Posted November 3, 2024 Just now, wolfie1 said: A number of reasons, i like the look of the other better 1 and it wont be for sale for Christmas Yea just saw it had different wheels and a later release date. Just bear in mind the BL2S one has plastic hexes etc so there maybe more differences that need upgrading to handle more power. Sometimes Traxxas put different geared diffs in their non VXL models which can become problematic Quote
wolfie1 Posted November 3, 2024 Author Posted November 3, 2024 (edited) 10 minutes ago, Kpowell911 said: Yea just saw it had different wheels and a later release date. Just bear in mind the BL2S one has plastic hexes etc so there maybe more differences that need upgrading to handle more power. Sometimes Traxxas put different geared diffs in their non VXL models which can become problematic I was reading up on it, the diffs appear to be the same, only differences in the driveline that i can see is the hexes you mentioned a centre diff and the propshaft is alloy as opposed to plastic, but being a traxxas there will heaps of aftermarket available for it Edited November 3, 2024 by wolfie1 Quote
Kpowell911 Posted November 3, 2024 Posted November 3, 2024 (edited) 8 minutes ago, wolfie1 said: I was reading up on it, the diffs appear to be the same, only differences in the driveline that i can see is the hexes you mentioned a centre diff and the propshaft is alloy as opposed to plastic, but being a traxxas there will heaps of aftermarket available for it Youve done more research than me but its basically a Slash 4x4 which is proven. That combo should work fine, Guessing youd run 3S? Id maybe look at a 4S system personally? Id probably go for a 6S lower kv system with a 40XX can and run 4S? Edited November 3, 2024 by Kpowell911 Quote
wolfie1 Posted November 3, 2024 Author Posted November 3, 2024 (edited) 2 hours ago, Kpowell911 said: Youve done more research than me but its basically a Slash 4x4 which is proven. That combo should work fine, Guessing youd run 3S? Id maybe look at a 4S system personally? Id probably go for a 6S lower kv system with a 40XX can and run 4S? I was thinking a 3s system, maybe i may look at a 4 Edited November 3, 2024 by wolfie1 Quote
