Brand new Remote Kill Switch for Largescales
rctruckz
Hi guys, I have a couple of these kill switches up for grabs which are brand new, I've personally been using these for a few years,  on my own largescales & they work flawlessly, these do exactly what they are meant to without the hefty price tag as some of the other "well known" brands! asking £30 posted, cheers 😉
Heres more info/specs etc! if interested drop me a msg here or pm me, cheers!
Large Scale Remote Safety Kill Switch
***£30 incl FREE POSTAGE (For UK Customers only***
This is the K2 Version that INCLUDES the coil harness! (NOT to be mistaken for the K1 version that has no harness!).
A must have device for your Large Scale models, with this device you are able to stop/kill the engine remotely with a flick of a switch on your remote! It will also Stop/Kill the engine should signal be lost between the model & transmitter so no more runaways!
Tihs version Inlcudes everything you need to make installation quick & simple including the Coil Harness! Be wary of others available that do NOT include this harness!!
Works with all Large Scale Gas/Petrol engines that use a coil, such as Zenoah 23/26/29/32cc CY Engines & also modded engines. Ideal for LOSI / 30DN / KM / HPI BAJA / MCD / FG & Many more!
Tried, Tested & Proven by many Largesacale hobbyists which makes this the perfect choice of Kill Switch for your RC Model!
Features:
  • Works on any Gasoline/Petrol engine land or sea with a magneto drive/coil ignition (not compatible with CDI driven ignition systems).
  • Very simple to install, No soldering, includes everything you need including coil harness!.
  • Remote LED to indicate if the ignition is live.
  • Fiber optically coupled to eliminate interference.
  • Li-Po/Li-Ion/LiFe/Ni-Cd/Ni-MH compatible.
  • Input range from 3V, 3 amps up to 20V, 16 amps.
  • Surface mount technology.
  • High-quality wiring with universal servo connectors.
  • Only 0.3 oz/8 g.
  • Manually shut off engine from assigned button/switch on transmitter.
  • Automatically shuts down power to the ignition on loss of signal or low voltage
Edited by rctruckz
  • 4 weeks later...
