MAZ Posted September 22, 2024 Share Posted September 22, 2024 I had to glue my Hyper ST tyres onto the rims the other day. First try didn't go well as I used the wrong type of glue (its all I had at the time so thought I'd give it a go) - total waste of time.. Got some gorilla glue to try again and just urgh.. its not gone well Gel glue is not the way forward.. The gel glue is too thick and the setting time is almost instant which isn't what I needed at all l Those blue bits are parts of the nitrile gloves I was wearing so as not to glue my fingers to the tyre/rim I'm just about to order some thinner glue that has a slightly longer drying time - this stuff: SLOW DRY Ammo Mig / Colle21 Super Glue Cyanoacrylic for a slower setting, 15 seconds, 21 g with precision cannula for model making and DIY. https://amzn.eu/d/4WClD8n I've also had a look on youtube at some tyre gluing vids to get some tips - gel glue isn't advised lol Just wondering if anyone has got any advice or tips on how to glue tyres without making an utter mess out of them? Cheers 🙂 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted September 22, 2024 Share Posted September 22, 2024 Get the tyre sitting on the rim correctly then just push a little bit back at a time, go sparingly on the glue and take your time 1 Quote Link to comment Share on other sites More sharing options...
SimplyChunk Posted September 22, 2024 Share Posted September 22, 2024 tyre gluing is just one of those things you have to build up a 'knack' for. I've been in this hobby for over 20 years now and still make a mess from time to time. I use this glue which I get from my LHS They also supply these precision nozzles too which help minimise the flow of the glue. That reminds me I've got to pick some more of these up when I'm down there next. So thanks for that. As @wolfie1 says. Put the tyre on the rim completely. Then just tease back the tyre and drop a little of the glue in. If you put a little too much there are two things you can do. You can left the tyre off the rim a little further forward on the tyre as you lower the previous part of the tyre back on the rim. What this does is create some space for the excess to go. The other thing you can do is keep some kitchen roll handy fold it a couple of times and before you wipe the excess wet it with your spit. What this does, if done right, is stop the kitchen roll sticking to the tyre when it touches the glue. Hope this helps 🙂 Also, wear eye protection you don't wanna glue your eyelids shut 😉 < like this dude did 2 Quote Link to comment Share on other sites More sharing options...
Partydaz Posted September 22, 2024 Share Posted September 22, 2024 7 hours ago, SimplyChunk said: tyre gluing is just one of those things you have to build up a 'knack' for. I've been in this hobby for over 20 years now and still make a mess from time to time. I use this glue which I get from my LHS They also supply these precision nozzles too which help minimise the flow of the glue. That reminds me I've got to pick some more of these up when I'm down there next. So thanks for that. As @wolfie1 says. Put the tyre on the rim completely. Then just tease back the tyre and drop a little of the glue in. If you put a little too much there are two things you can do. You can left the tyre off the rim a little further forward on the tyre as you lower the previous part of the tyre back on the rim. What this does is create some space for the excess to go. The other thing you can do is keep some kitchen roll handy fold it a couple of times and before you wipe the excess wet it with your spit. What this does, if done right, is stop the kitchen roll sticking to the tyre when it touches the glue. Hope this helps 🙂 Also, wear eye protection you don't wanna glue your eyelids shut 😉 < like this dude did Yip double thumbs up on that advice, that tyre glue is brilliant for tyres I know It sounded daft when I typed it 😆 but it's good stuff especially with the little nozzle makes it way easier to use as the tyre glue is thin and runs around the wheel very easy. 1 Quote Link to comment Share on other sites More sharing options...
Redback Posted September 22, 2024 Share Posted September 22, 2024 (edited) i love beadlocks 🤪 gluing to me is ruining a set of nice tires i can put on other rims at the drop of the hat, why do people still glue? edit: ugh 1/8th yeah horrible, very thin in the lip and drop it in, or pre mount and glue the outer bead with very fine cappilary super glue, you can see it spead along the seam, apply at 1, 2, 3 o'clock and so on. Edited September 22, 2024 by Redback Quote Link to comment Share on other sites More sharing options...
Ziggy122 Posted September 22, 2024 Share Posted September 22, 2024 Nitro we got away with Hot Glue Gun applications.... but there are many a time, I've stuck projects to the table / fingers together / finger to projects / tyres not glued properly.... yeah Rushing doesn't help I hated the think Instant glue, it always ran too well and this is where the problem occurred... setup 100% before going in for the glue.... 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted September 22, 2024 Share Posted September 22, 2024 Yehh its a tad embarrassing trying to get yourself unstuck from your model cause its run to well or you used to much 2 Quote Link to comment Share on other sites More sharing options...
wombat Posted September 23, 2024 Share Posted September 23, 2024 Always use beadlocks on the crawlers, but on the sct and typhon just use normal gorilla super glue and never had a problem, but ungllueing them is a different story, lol ☹️ 1 Quote Link to comment Share on other sites More sharing options...
