Posted
Hi, I need 2 x micro brushless 35/40amp esc measuring approx 26/13/5mm
i currently have 2 x readytosky, but these are setup with a center throttle input already, I’m using them in a car, so need standard fwd/rev/brk
running 2  brushless drone motors (one per wheel) so running 2 esc (each one controlling one motor) using the mixed motor axle setting on the tx.
any recomendation?
Posted
Bit late, but check gt55racing, they specialise in miniature drift ESC, they're around the size you mentioned (not quite sure about height though). My Rocket Kiwami is slightly higher than your requirements, otherwise they fit.
Worth giving a browse.
