Micro battery connectors
wombat
As the title says, does anyone know  which micro connector the ftx utah comes with, as it is only described as a micro connector, but not which one, I am wanting to make up  an adapter lead with a female deans on the other end so i can storage charge and balance charge the battery using my sky rc charger,
Cheers all, Ian
Finally found the right connector, if it helps anyone the connector you need is a Micro JST MX2.0mm Molex 2 pin , just got mine, soldered it to a female deans, can now charge and storage charge using my sky RC charger
