Posted
Hi, my ftx Utah came with a 600 mah rated battery, has anyone found a higher rated battery that fits, with the same connector, or am I better off just buying a couple more of the 600 mah batteries
Also, the are charged with a usb charger via the balance lead, so how do you storage charge them ?
TIA 😄
Posted
TIA 😄
The Utah ships with a smaller battery i think its a 360mah 2s and these are a pain to put to storage you need an adaptor cable to be able to plug into a hobby grade charger to do this, i think 600mah is about as big as you go
Posted
That's what I suspected, will get a couple more 600 mah batteries, and to storage charge will keep checking with
a voltmeter until the right voltage
Posted
Good news, after seeing the connector, my son who works in It, and builds computers as a hobby/second job has said he can make an adapter lead so I can use my sky RC charger 🙂
