New controller and reciever
Leslie
2 hours ago, Redback said:
Signal wire should be on the left side, black cable to the right side.
Flip the cables around and it should work, keep servo in chan 1.
Hi I did what you said and now the steering works as it should, but there is still nothing on the throttle and I have a constant red light on the esc which was not on before
On 24/07/2024 at 18:11, Stormbringer said:
check you havnt any throttle trim on as it wont arm if theres some trim on
also you could try recalibrating the esc
Hi I have adjusted the throttle trim and the car is moving forward with no reverse, but on my controller I have a reverse button that when you turn it on it reverses everything so left is right and right is left and the same on the motor reverse becomes forward etc. So in this mode I have reverse and forward but reversed on the trigger. I hope that this makes sense
