Posted
So when you have a winch controller, the esc, and a BEC to plug into the battery what is everyone’s preferred method for these kinds of shenanigans?
Do I solder them all to the same battery connector? I’d probably use a wee bit of lead to solder to as packing 3+ wires on a dean plug is possibly getting sketchy depending on wire gauge.
Or do I use stacked battery connector flyoffs for each of the esc, bec and winch?
Or a bus bar setup?
How does everyone deal with this?
Posted (edited)
I'd solder the bec to the esc battery connector.
I don't bother with deans connectors I much prefer the xt60 connectors. But that's just personal preference.
As for the winch controller I don't know as I don't have one.
Edited by steephill
Posted
You could solder the winch controller to the esc battery lead at same time as you do the bec but i use XT90 connectors in mine
Posted
I like the idea of the XT family, especially with the antispark, but I’ve got the 90s on my USA-1 and they seem to end up with fine dust in the shroud and it makes them a total pain to separate and connect so I’ve just lazily stuck with Deans for the lower amperage cars. I really must swap to a more modern connector someday, but not today😂
I’ll fire it all together as suggested and see how I get on with it. Thanks for the sanity check👍
