Repairs/spare parts?
Bigfoot
I managed to damage my brand new Bigfoot no 1 truck after 30 mins of driving it around the yard. See attachments.
I assume I should be able to fix it myself but where do I find the exact parts i need for this model?
also I am rather surprised how fragile it is. I did not do crazy stunts with it and would expect it would be more robust have I missed something?
https://www.modelsport.co.uk/product/29284
Thats the stock part, its quite a weak are, the issue with the Bigfoot is as good as it was at launch its getting over 20 years old now, and things have moved on a lot.
Upgraded RPM parts
https://www.modelsport.co.uk/product/rpm-traxxas-2wd-front-bearing-carriers-black-15472
You can find also find alloy upgrades, but dont go too far with them
10 hours ago, Bigfoot said:
Awesome thanks for the help! So if I order these
that should be enough and they are better than the ones that it came with?
You also need 4 of these if you upgrade to those RPM Carriers
https://www.modelsport.co.uk/product/modelsport-uk-bearing-5x11x4-1053
Ok so 4 of these:
and 4 of these:
to fix the current problem?
are there something else I might as well order for any easy/recommended upgrades to make it more robust?
2 hours ago, Bigfoot said:
Ok so 4 of these:
and 4 of these:
You just need 1x pair of RPM front carriers and 4x bearings.
There are a few parts to upgrade to make it stronger but I wouldn’t worry too much until you actually break a part. Just use it and upgrade as you go
