MrMcG's Modded X-Maxx AKA the Green Meanie
MrMcG
A long overdue but brief update -
Went for a blast at Beckenham Place Park, something close and lots of space.
Rain and weather had turned most areas into mud bogging which was great fun to be fair and we had a blast for around 35mins
The last pic before disaster
5 mins after this all hell broke loose...
full throttle coming towards me and it just cut out the nose dipped and dug in and an incredible gymnastic routine was observed
in short after a quick look
  • Cracked bulkhead
  • Suspected front diff or ring and pinion
  • Steering link
  • Servo arm
More upsetting is the fact the ESC seems to have exploded
Max 6, the switch no longer works and it cuts out randomly (tried different batteries)
OUCH!
Looking at this now as a replacement
https://www.modelsport.co.uk/product/castle-mamba-monster-x-8s-336v-esc-w-1717-1650kv-sensored-motor-1334720
Will upload pics of all the damage as I find it 😄
  • Sad 1
Attacked the car today to see what was up with the front diff.
Ominous start...
Here we go
Hmmm its fine
Oh..
Well that explains that and its far better than the expected ring and pinion failure that I initially expected!
ESC still dead though 😄
1 hour ago, Stormbringer said:
at least you found whats up with the drive but pity about the esc
Ill take it.
New ring and pinion setup was around £60/70 instead its a £15 shaft. 🙂
Its due a rebuild and clean up so ill take this chance to do it and see what else needs a bit of TLC. The mud bogging and swimming I have done with it has rusted bearings but on the whole with the abuse it gets... Can't complain.
It is an incredible RC car.
12 hours ago, Tadas said:
Could you link these:
And how do they feel? actuall protection or just for the show?
Sure,
These are the boots https://www.ebay.co.uk/itm/143394151191
IMO they provide actual protection from the elements and conditions, I will always run them when I have them 🙂
  • 2 months later...
Well after much money spent
Its back in action -
Parts list
Max 6
1250kv
Scorched RC motor mount
Scorched RC gear cover
Mod 1 gears
Center shaft
Bearings
servo arm
Its now back in prelim action, need a quick shakedown first before giving it the beans and full photo shoot.
I will say the motor mount is stunning!
54453807082_7de2e94365_b.jpg 54454846394_3e035f741f_b.jpg 54455013475_365d37eb12_b.jpg 54455013575_4e6a8f668a_b.jpg
On 02/02/2025 at 11:12, MrMcG said:
removed the shaft and began stripping down.
Hell of an effort
How?!!! How did you managed to do this?!! 😁😁
1 hour ago, wolfie1 said:
I have the same mount on my xmaxx, i stuck a piece of high density foam between the motor and mount at the rear to help against bending stuff
Thats a great idea!
Will do that thanks
I honestly wish I knew.
All I heard was crunch and then rear wheel drive only!
Were you doing high jumps with it or just speed runs?
Id given it hell for months to be fair, but when this happened I was driving towards myself hit the brakes and all hell broke loose 😄
I think i mentioned this before on this thread, i am going to take a guess at sandy stuff getting between the bash block and the shaft and over time has worn the shaft away until it was so weak it snapped
