Cheap eBay SCX10 Pro
Andy-Roo
38 minutes ago, stretch said:
Got a bargain there mate. I'm the same as you I hate it when suspenders are too hard and high😆
Yeah, makes ya voice go all high pitched and squeaky 😂
  • 4 weeks later...
Afternoon all..
I sneaked into the garage this morning to try and get the electrics finished off, but was very limited on time.
It didn’t go to bad really and although the layout could probably be improved when I powered it up, no smoke can out! So that’s a win.
Even though the RX and BEC lite up I couldn’t find the bind plug for my GT5 so didn’t get to run up the motor or servo.
So the plan this week is to find that bind plug (or see if I can buy another one), get it fully powered up, setup the motor and BEC, set the end points on the steering, swap out the single stage foams for duel stage PL’s and see if it runs okay.
Hopefully I’ll get all this done by Friday 🤞
I really don’t like a messy bench
The layout I’ve settled on
That’s it for now, but hopefully I’ll get some time this week to finish it off.
if you have a spare servo lead you can make 1 as all it is is a loop of wire conecting the 2 outside connectors together (signal to negative)
Thanks for the info bud 👍
I’ve just been online and bought another one…it was then I realised it’s a universal thing and just bridges those two posts in the RX.
I’ll come across the lost one now I’ve ordered a new one 😂
1 hour ago, steephill said:
Looking good 👍. I didn't think of mounting the battery up front like that,good idea.
Thanks bud.
 I came across a forum post where a guy 3D printed a battery/electronics mount that sat over the transmission. I don’t have a 3D printer but it got me thinking about where the battery would be best placed. The servo mount seemed the perfect spot and as luck would have it, 3 of my lipo’s fit perfectly on it. Result 😎
On 09/06/2024 at 19:12, Andy-Roo said:
Thanks bud.
If you can get the STL file Incan print one for you.
That’s very kind of you, thanks! 🙌
If I can get hold of the file I’ll let you know 👍
IT LIVES!
https://i.imgur.com/DbUuVIc.mp4
I got an unexpected early finish from work today, so rushed home to try and get this truck running.
The new bind plug had arrived so I got the TX/RX bound and the electrics powered up. So far so good. The servo centred but the horn was off centre by one spline, and it wasn’t pulling full lock to the right.  So I had to hook it up to the laptop and adjust the neutral position and now it pulls full lock, both ways.
Next up was getting the motor set up…which was a breeze. And then it first drive time! Only in the garage but all went well but tomorrow I’m hoping to get it out on some rocks to see how it does.
I will, of course get pics and vids 👍
@steephill Thanks bud. The mad thing is the BEC is still on factory settings because I ordered the wrong Castle link kit (doh!) so had to reorder the right one, which hasn’t arrived yet - can’t find my field link anywhere 🤔
I got it out on some rocks today….but I had to buy my other half lunch as payment though 😂
I’ll upload pics and vid soon.
  • Haha 3
So today I got the truck out on some rocks for a shakedown run, and it did okay.
It had been raining on and off all day so conditions weren’t ideal as far as grip went, but overall I’m pretty impressed.
The rocks
Not sure if these vids will come out okay, but filming and driving one handed was tricky.
https://i.imgur.com/LiKXcmW.mp4
hTv1EPl.mp4
https://i.imgur.com/eocPo0L.mp4
Don’t why some of these just show as links 🤷🏻‍♂️
So, I think the shocks on the front are too stiff and need lowering some. Also the dual stage foams were moving about in the tyres to much so maybe inserts would be a better option.  Anyway, I think it’s good truck and I’m looking forward to tweaking a few bits to try and get the best out of it.
It'll also be interesting to put it up against the Interceptor on the same lines for comparison.
That looks a great place to test your rig.
I had a set of dual foams the moved about. I pulled off one side of the tyre and put a few blobs with the hot glue gun, a bit rough I know. But it worked.
It's also a good opportunity to get some upgrades though 😉
I like to do comparison tests. Definitely worth a trip back for playing with your truck, I mean testing 😉😂
Apparently the spring are the same as mini T springs. Last time I looked I couldn't find any for the 10 pro.
