Lcg crawlers
steephill
@steephill That looks decent and would be good to see it up against a high end LCG from one of the big hitters - I’d bet there wouldn’t be much in it.  I had an LCG itch 3yrs ago that I never scratched, and it came back recently after I decided to rebuild my 10.2 - that’s why I put the wanted add up.  I joined the GS U.K. Facebook group and one of the guys on there sold me a set of stock Capra axles (waiting on their delivery) That’s the first step towards scratching that LCG itch.  You’re not helping with posting pics of your sweet TRX4 though 😂
  • Haha 2
 I've ordered a Rhino yue one V2 chassis kit.
Rhino capra axles, chassis, gearbox, links and driveshafts.
So I'm gonna need wheels, tyres, shocks (probably 90mm desert lizards). I've got a 80a Rhino esc and 2250kv outrunner. And I have a 9imod 55kg servo that's pretty quick.
And I'm not sure about the body. I ideally don't want to end with a 3rd of what's left of a perfectly good lexan body chopped up.
So any suggestions will be welcome.
13 minutes ago, Stormbringer said:
mind you getting a body to fit it might be a challenge tho
I've got a few that I can use to see what's going to fit the best.
I've got a few proline cliffhanger, jconcepts creep, ftx texan cab and a few others so hopefully something will work.
15 minutes ago, Andy-Roo said:
Kinda looks like an MOA rig from that angle, and I know you said you didn’t want to chop up a shell, but that shape says ‘chopped Beatle’ to me 😎
It's more than likely gonna go that way 😂 I imagine there wouldn't be much left of a cliffhanger or creep body left.
Made a start on another chassis I got from aliexpress a while ago.
I had to pull a truck to bits as I needed the axles.
I've used a aliexpress lcg gearbox with overdrive, comes with a delrin skid.
Desert lizard shocks, again.
Injora brushed 5 slot motor, I've just finished soldering a 1080.
A few bit to do, work out where the battery, esc and receiver are going. Fit drag link and servo horn.
I'm going to get it running and test tomorrow.
IMG_20240521_200822 IMG_20240521_200854 IMG_20240521_200939 IMG_20240521_201014
I've got a proline 78 chevy k10 body I think I'm going to use for this one.
So far very good value. The chassis is about £40 with a delrin skid.
1 minute ago, Stormbringer said:
looks good and getting a body to fit it will be easier than the other 1 :good:
Yeah mate 👍. I've sat the k10 body on and it looks good.
It's a 313mm wheelbase chassis for a scx10 ii so should fit alright.
