stretch Posted April 21, 2024 Share Posted April 21, 2024 Steel Frame Ladder The frame of GS02F chassis is designed to look like real cars’. It is made of high strength steel and the C-channel side rail with hex wrench bolted cross members make it resistant to twisting and warping. The steel parts are finished with powder coats to prevent rusting. Inner Fenders The inner fenders are directly fixed to the frame to reduce flex and bend of the chassis and parts. They also avoid external objects entering into the chassis during the driving. Extended 347mm wheelbase Extended wheelbase makes climbing and rough terrain driving more stable and smoother. Front Weight Balance Weight balance of the GS02F chassis is leaning forward. This increases traction of the front wheels and provides better crawling performance at high angle hills or rocks. It also minimizes rolling over backwards when climbing. Multiple Battery Size Size changing battery tray of the GS02F chassis can hold all sizes of Lipo and Ni-MH batteries. Overdrive Overdrive system means the front and the rear wheels rotate for different speeds. The GS02F transmission is designed to rotate the front wheels faster than the rear wheels. Better Steering Radius Vehicles with overdrive front wheels turn with shorter steering radius compared with non-overdrive vehicles. The overdrive also makes the control easier when the car is driving on rough surfaces. 2-Speed HI/LO Transmission The 1st gear is for hardcore rock crawling and the 2nd gear is for hill climb or high-speed driving. Torque Twist Reduce Transmission TTR(Torque Twist Reduce) transmission is designed to reduce unnecessary torque so the vehicle will drive with more stability. From the transmission, the front and rear universal shafts rotates clockwise and counterclockwise, and these opposite rotations compensate for rotational forces of action(torque) and reaction(reverse torque). MT-1905 1.9 Inch M/T Off-Road Tyre The MT 1905 off-road tires, made of super soft compound material provide much traction to the surfaces. The tread patterns are suitable for off-road driving and the large diameter of the tires enables it to run smoothly on any uneven road surfaces. Tyre Specifications Tyre Height: 121mm Tyre Width: 45mm Inner Diameter: 48mm (1.9") SPIDER LEXAN BODY The spider body is a NO TOP style body made of high quality 1.5mm lexan with high strength and details. To add realism details it includes front grille, light bucket, side mirrors, wipers, driver seat, steering wheel, shifter, overfenders, roll cage and a LED light bar so you can tune into a realistic off-road vehicle to matches the concept of off-road adventure. The accessory parts are made of high-strength plastic so they are resistant from the highly impacts, and include decals with realistic details. Car Specifications Width: 269mm Height: 255mm Length: 486mm Wheelbase: 347mm Ground Clearance: 82mm Weight (No Electronics): 2.36kg Front Approach Angle: 79 degree Rear Approcach Angle: 90 degree https://www.gmade.net/product/gmade-110-gs02f-spider-portal-ts-kit/2255/category/324/display/1/#listproduct_product View full news article 1 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted April 21, 2024 Share Posted April 21, 2024 Interesting new model, a nice change from the usual stuff Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 21, 2024 Share Posted April 21, 2024 quite an influx of new decent spec crawler/trail trucks these days 1 Quote Link to comment Share on other sites More sharing options...
ninjagaiden Posted April 22, 2024 Share Posted April 22, 2024 Very nice. OD and 2 speed out of the box! Quote Link to comment Share on other sites More sharing options...
