Ftx outback tracker or element titanium hd
Country mike
Hi I was wondering which is the better buy out of the ftx tracker or element titanium, i used to have an outback 2 but I wanted a car from a decent company (I.e. element), but then ftx brought out the tracker.
On 03/04/2024 at 07:27, Country mike said:
Thanks, I will probably choose the element because of the better parts supply and being owned by a bigger company
Did you decide yet, another to look at is the new FTX Centaur, its a stunner
Yeh thanks I bought the element, works very well, completes every problem I tried with my old outback 2. Only issue I have is it's squeaking after its first run. Just wondering what that issue would be.
We tend to use a red sticky bicycle grease in our crawlers but dont see any reason not to use lithium grease
dif oil will probably leak out as they may not be sealed
Grease also helps stop water ingress
Iwould use gt85, lithium grease will attract dirt etc. In my axles i use some blue waterproof marine grease that i used for kingpins and bearings when i used to offroad a 1.1 suzuki jimny
