MF-01x Fiat 131 rally
Lone-wolf
12 minutes ago, Kpowell911 said:
It should handle it fine, but Id definitely want a bearing kit with it!
yep i built it with full bearing kit, and locked rear diff, open front diff. Waiting for the rally body shell to come in stock then i can get cracking and do it box art
The 13t blue 540 can finned motors were commonly used in the states for M chassis. They were very popular over here for a while, they won't ever set any speed records however for under £20 delivered you can't go wrong - https://a.aliexpress.com/_mritdw4
If you don't want that then the red 3650 surpass motors are incredible value for money. A lot of the budget speed runners use them and yeld very good results.
https://a.aliexpress.com/_mtGucnK
For 1/10 bashing you can't go far wrong with these motors.
the blue finned F540 motor is what i have just black and 3300kv, im good to go with it just a bit concerned the transmission might strip out, of course avoid heavy braking and dont slam from forward to reverse
Naa it will be fine, if not order some reinforced m chassis gears (black ones)
On 21/11/2023 at 19:01, Lone-wolf said:
project sort of on hold, ordered the fiat clear body as it was due in stock in 2 days, but already been put back to some time in December, may end up an xmas project
That's a good reason to get some upgrades ordered 🤣
If you haven't already got these then one piece carbon arms, CVDs  and TL01 speeds gears would be nice additions. PJ has now started offering cheaper shipping (less than £15) and they arrive within 1-2 weeks.
Edited by Alex97
Nice idea but i have always found the MF-01x to be a nice chassis as it is, im dreading doing the new body but it will be worth it once done, i did remove the 1040esc this morning that in all honesty has done stirling service, its now got a 1060 in it as im sticking with brushed....i do need to decide if i keep the M06 hopped up chassis or move it on though
5 hours ago, Lone-wolf said:
The thing is its such a lovely shell i dont want to bugger it up
Go for it, after seeing pics of your other cars, especially the Alfa you shouldn't have any worries, just trimmed a cliffhanger shell for my mauler, kept putting it off but wasn't too bad once I'd started
