The Traxxas trx4m owners thread
Gaz!
Looking great mate :good:
are they Injora wheels with the Traxxas tyre rings??
i have a set of those wheels, they are a very nice looking wheel i reckon….
14 minutes ago, Stormbringer said:
Yes they are injora wheels with the injora traxxas tyre wheel weights
I've got those brass rings on my k10 high trail (need to low trail it).
They are quite heavy but make the truck so much more stable.
The poor thing was struggling to drag it's fat ass up the crawler course with the stock gearing.
On 25/05/2024 at 09:09, steephill said:
Back on the 1.3 wheels with injora xhx tyres and fitted high clearance links.
I gave it a little test last night and the crawler course was wet through and quite slippy in places. It did brilliant, I'm well impressed with the performance.
IMG_20240525_085941 IMG_20240525_085958 IMG_20240525_090023
so what is needed to build this from parts direct from injora
@Lone-wolf
k10 length high clearance links & dr
Kangaroo chassis, battery and esc mount included.
Overdrive front underdrive rear 16%
Aluminium gearbox & 32% underdrive gears. Just my preference for crawling.
59mm shocks or 53mm will work to.
I've got +4mm diamond axles and lay down servo works with the chassis. But any axles will work.
Brass hubs with weights
I've got aluminium beadlocks 1.3 weighted.
Xhx tyres 1.3 (well
180 motor and injora esc is fine.
I run furitek stinger because it's tiny.
All your high trail parts will bolt straight on the kangaroo chassis to keep it as budget as possible.
Just now, Lone-wolf said:
Thanks, sounds like it would be a pricey build as i would not use parts from F-150
Not particularly cheap. But a really competent, durable mini crawler.
I love the kangaroo and tarantula brilliant little crawlers
i might put the parts in cart at some point to cost it up cheers mate
