rccar4life Posted August 9, 2022 Share Posted August 9, 2022 https://www.arrma-rc.com/en/product/1-7-limitless-v2-speed-bash-roller/ARA7116V2.html Optimized for 8S power, this evolution of the ARRMA® LIMITLESS™ 1/7 Scale Speed Bash Roller lets you go even faster than before. Now you can own the RC super car that beat a championship Formula One machine by running a quarter-mile in 8.6 seconds! THE NEW SPEED KING, AND NO ONE WRITE ABOUT THIS. I FEEL SICK ABOUT THIS ARRMA CANCEL things here NEW FEATURES Easy-access sliding motor mount accepts larger diameter motors 3mm Chassis plate repositions the motor mount to also accept longer motors 39T Mod 1.0 Spool with long rear outdrive combines with a shorter rear center driveshaft to reduce drivetrain vibration Easy-access electronics module accepts larger ESCs and includes a waterproof* receiver box Safe-D input cups are included on the front and rear gearboxes GP5 gears have a lower ratio for reduced centerline drivetrain speed and vibration Wider rear track increases stability Stiffer front springs and sway bar improve high-speed handling The first ARRMA “Rattle Can Roller” includes a clear, low-drag body for your own unique paint scheme — window mask and decals are provided EXISTING FEATURES Tunable aerodynamics — trim lines on the front and rear wings allow you to tune the downforce and drag Includes dBoots® Hoons™ All-Road tires on Speed dish wheels Two large battery straps with two perpendicular hook-and-loop battery straps provide reliable battery retention Front-to-rear chassis brace increases longitudinal chassis stiffness Heavy-duty servo saver Durable steel driveshafts Big bore aluminum shocks Black anodized front and rear shock towers Independent double wishbone suspension front and rear THE NEW KING OF SPEED BASHERS! Taking over from the original LIMITLESS™ 1/7 Scale All-Road Speed Bash Roller, this new evolution of the LIMITLESS Speed Bash vehicle has been “Designed FASTER” so you can reach higher speeds than ever before! ARRMA® engineers have improved the already proven LIMITLESS platform to accept bigger motors and larger ESCs — just add your choice of electronics to create an RC super car. The LIMITLESS 1/7 Scale All-Road Speed Bash Roller sits at the very top of the ARRMA Speed Bash range. It’s the new King of Speed Bashers! In fact, in a head-to-head contest with the real championship-winning, Red Bull Racing RB7 Formula One car, the LIMITLESS 1/7 Scale All-Road Speed Bash Roller came out on top. Reaching speeds of up to 150 MPH, it ran a quarter mile in just 8.6 seconds! Because the LIMITLESS 1/7 Scale All-Road Speed Bash Roller lets you pick and choose your own electronics package, you can adapt the power system to meet your needs as your speed run skills progress. ARRMA has refined this rolling chassis with transmission and motor mount parts that are optimized for 8S high-speed running. New features to the LIMITLESS platform include a 3mm anodized aluminum chassis plate that repositions the motor mount to accept longer motors. Easy Access Sliding Motor Mount can fit larger diameter motors with optional motor mounting plate, while the electronics module accepts larger ESCs and incorporates a waterproof receiver box. Additional changes have been made to increase stability for confident control at high speeds. The 39T Mod 1.0 spool with long rear outdrive combines with a shorter rear center driveshaft for equal length center driveshafts and less drivetrain vibration. Lower ratio GP5 gears reduce centerline drivetrain speed and vibration. Stiffer front springs and sway bar improve high-speed handling, and a wider rear track increases stability. Carried over from the original LIMITLESS, big bore oil-filled shocks on black-anodized front and rear shock towers keep the dBoots® Hoons™ all-road tires firmly planted for maximum traction over on-road, light off-road, loose gravel, short grass, dirt, and oval tracks. Besides being the fastest ARRMA Speed Bash vehicle, the LIMITLESS 1/7 Scale All-Road Speed Bash Roller is also the first ARRMA “Rattle Can Roller.” The low-drag body comes unpainted, ready for you to personalize it with your own unique paint scheme. Window mask and decals are included. Trim lines on the front and rear wings make it easy to tune the downforce and drag. The ultimate RC speed machine experience is here. Install your choice of electronics, paint the body in your signature colors, and create your own high-speed RC super car with the ARRMA LIMITLESS 1/7 Scale All-Road Speed Bash Roller! Now im gone BYE 1 Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted August 9, 2022 Share Posted August 9, 2022 (edited) I genuinely mean this @rccar4life Im glad youre back. Although not much interest in this as its not much different to the old one? Edited August 9, 2022 by Kpowell911 1 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted August 9, 2022 Share Posted August 9, 2022 2 hours ago, Kpowell911 said: Although not much interest in this as its not much different to the old one? Needs less modifications to fit XLX2 and big cans. .. that's about it. Oh, and of course, it's 33% more expensive now. 1 Quote Link to comment Share on other sites More sharing options...
James.S Posted August 10, 2022 Share Posted August 10, 2022 22 hours ago, rccar4life said: Now im gone BYE 🤞 2 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted August 10, 2022 Share Posted August 10, 2022 My bad, i missed that you had to pay for the privilege of not getting a painted body. Which of course is an upside, i tend to love when i have to pay more for less. I don't care what other countries pay, it's 33% more expensive here, where the majority of members of this forum live. Now keep to your promise please. 2 1 Quote Link to comment Share on other sites More sharing options...
