Lipo dead?
Hi all,
Trying to charge / balance my 2s lipo batteries and getting the following error…
Battery check. Over Voltage.
I haven’t used the batteries for 2 years. I thought I put them in storage mode but maybe didn’t.
Do I have a couple of dead lipos?
If so, can anyone suggest a good replacement please? Nothing too expensive.
Thanks in advance.
over voltage usually comes in when uve set the wrong cell size too buddy or wrong mah  is it defo on 2s (7.4v-8.4v)
it is yeah, iv checked and checked the settings on the overlander and defo correct.
also just totally drained the batteries. Still the same 😞
26 minutes ago, vinniejones said:
i have had this where it wouldnt charge saying over voltage and it was the balance lead that wasnt connecting properly
Ah ok, I really hope it’s this! What can I check? Try? Please.
5 minutes ago, vinniejones said:
well if you had another balance charger or a balance adaptor lead
is it worth me buying a new charger rather than new batteries?
1 minute ago, noddy_2121 said:
I haven’t but I shall try
have a look on youtube as that helped me out when i had a problem with one of my lipos. i just cant fully remember the details. i think when you put it on nicd charge mode, you dont use the balance lead.
mmmm seems to be doing something 😊
thats great!
another thing that i did too is charge it above 3v each cell then put it back to lipo charge.
Posted (edited)
32 minutes ago, froggy8 said:
oh you need to charge it at 0.1a
and how long should I leave it? Until it says charged? Then charge again on Lipo?
Edited by noddy_2121
Re read the cell voltage as you just need to get them >3.0V per cell, otherwise most lipo chargers wont start charging.  I suspect the battery isnt in good condition if its reading <3v per cell after 2 years storage.
It now seems to be charging on the 2s lipo setting… after using the NiCd setting to get the cells above 3v.
 Share
