Tom1208 Posted February 19, 2022 Share Posted February 19, 2022 (edited) Hi everyone, i need a bit of help please. i recently bought my son a second hand hpi trophy flux buggy. it needs a bit of TLC. We stripped it down, painted it and are almost ready to rebuild. Awaiting diff oils. the esc came with no fan or surrounding shroud/ casing. does anyone know what size of fan is needed ? The screw holes are about 25 mm. also does anyone know where i could get either the proper shroud and fan for the esc. If anyone has an old burned out one i could buy the parts i need from you ? or even the proper size of fan i need ? i am a tad confused if it would be a 25mm because of the bolt hole size or if it would be a 30mm fan because of the casing size. Thanks guys 👍🏼 Edited February 19, 2022 by Tom1208 Quote Link to comment Share on other sites More sharing options...
Glenn75 Posted February 19, 2022 Share Posted February 19, 2022 I've got the trophy flux will give you some dimensions on the fan and case ,I'm at work at the moment but will have a look when I get home, if I remember right the fan doesn't bolt to the Esc it just fits inside the case. Quote Link to comment Share on other sites More sharing options...
Bajadre Posted February 19, 2022 Share Posted February 19, 2022 is it the 6s hpi esc tom? like glen said the fan attaches inside the case and just connects to white 2 pin on the right of your piccy mate Quote Link to comment Share on other sites More sharing options...
Tom1208 Posted February 19, 2022 Author Share Posted February 19, 2022 Thanks very much guys 👍 I appreciate that glen. I thought it’s a 4s esc but looks very similar to the one in that video. The only difference I can see is the one in the video has the power switch holder attached to the side of it. My one has a separate tray the esc clips in to. there’s unfortunately no part numbers or anything left on it to identify the esc. If I can’t get a case could I still screw a fan on the top using the bolt holes on the esc ? 1 Quote Link to comment Share on other sites More sharing options...
Bajadre Posted February 19, 2022 Share Posted February 19, 2022 (edited) yeah tom they did a 3s 4s 6s version over the years 👍 yeah if you can get the width right it wont matter how deep the fan is to fit in the top case you can ziptie the fan over the heatsink then, did that a few times 🙂 Edited February 19, 2022 by Bajadre 1 Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted February 19, 2022 Share Posted February 19, 2022 Would buying a new ESC not be more sensible? Quote Link to comment Share on other sites More sharing options...
Glenn75 Posted February 19, 2022 Share Posted February 19, 2022 6 hours ago, Glenn75 said: I've got the trophy flux will give you some dimensions on the fan and case ,I'm at work at the moment but will have a look when I get home, if I remember right the fan doesn't bolt to the Esc it just fits inside the case. I've just had a look at mine its the same design as the Vorza the fan fits inside a shroud then there's a cover over it that holds the wires. I would just bolt a fan to the top of the heat sink and double side tape the Esc down, if you need some images let me know. 1 1 Quote Link to comment Share on other sites More sharing options...
Tom1208 Posted February 19, 2022 Author Share Posted February 19, 2022 Cheers lads 👍 I will just screw a fan on top. The screw holes are about 25mm apart so would I get a 25mm fan or would it have to be the 30mm to compensate for the fan housing thickness ? Quote Link to comment Share on other sites More sharing options...
Tom1208 Posted February 19, 2022 Author Share Posted February 19, 2022 5 hours ago, Kpowell911 said: Would buying a new ESC not be more sensible? Na mate, the car was only £100. the esc is coming in between £80 - £130. to expensive for me at the moment. a fans only about a tenner 👍 Quote Link to comment Share on other sites More sharing options...
Glenn75 Posted February 19, 2022 Share Posted February 19, 2022 Don't think you'll need a fan in this weather😁 1 1 Quote Link to comment Share on other sites More sharing options...
