Powell987 Posted January 29, 2022 Share Posted January 29, 2022 There seems to be alot of play in the steering/ wheels after using a few times! Any suggestions on what this could be or is this just expected? Should there be a little bit of play as when i first got it there didn't seem to be ? Would replacing plastic steering parts for metal ones help at all ? Thanks Quote Link to comment Share on other sites More sharing options...
froggy8 Posted January 29, 2022 Share Posted January 29, 2022 (edited) 6 minutes ago, Powell987 said: There seems to be alot of play in the steering/ wheels after using a few times! Any suggestions on what this could be or is this just expected? Should there be a little bit of play as when i first got it there didn't seem to be ? Would replacing plastic steering parts for metal ones help at all ? Thanks you could try shimming it mate Behind the bearings between the bearing face and axle Edited January 29, 2022 by froggy8 Quote Link to comment Share on other sites More sharing options...
Powell987 Posted January 29, 2022 Author Share Posted January 29, 2022 What size shims would i need ? Do you have a link for these ? Thanks Quote Link to comment Share on other sites More sharing options...
froggy8 Posted January 29, 2022 Share Posted January 29, 2022 sorry i dont have an arrma typhon but i did a quick search and came up with this: this guy used: 8x12x0.2 shims between the hexes and outer bearings, and 12x18 shims (some 0.2mm thick, some 0.5mm) behind the inner hub bearings Quote Link to comment Share on other sites More sharing options...
froggy8 Posted January 29, 2022 Share Posted January 29, 2022 it is a new car isnt it? Quote Link to comment Share on other sites More sharing options...
lorrylemming Posted January 29, 2022 Share Posted January 29, 2022 You need to work out where the play is in the steering or suspension. It could be anywhere between from the servo to the wheels, or more than one place. There's no point carefully shimming the wheel hexes for example if your servo saver is loose and wobbling. With the car turned on, try pushing the wheels by hand and watch the servo push against you. You should be able to see where the play is in the system. Quote Link to comment Share on other sites More sharing options...
Powell987 Posted January 29, 2022 Author Share Posted January 29, 2022 Ok i will look more into it ! Yes the car is new i have ran it about 8/9 times now? Quote Link to comment Share on other sites More sharing options...
Powell987 Posted January 29, 2022 Author Share Posted January 29, 2022 The play Is on all 4 wheels Quote Link to comment Share on other sites More sharing options...
Powell987 Posted January 30, 2022 Author Share Posted January 30, 2022 18 hours ago, lorrylemming said: You need to work out where the play is in the steering or suspension. It could be anywhere between from the servo to the wheels, or more than one place. There's no point carefully shimming the wheel hexes for example if your servo saver is loose and wobbling. With the car turned on, try pushing the wheels by hand and watch the servo push against you. You should be able to see where the play is in the system. IMG_1952.MOV Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted January 30, 2022 Share Posted January 30, 2022 My Arrma Kraton EXB had play all over it out of the box…… just think its how they are….. Quote Link to comment Share on other sites More sharing options...
lorrylemming Posted January 30, 2022 Share Posted January 30, 2022 Watching the video, the play is quite a lot and its near the servo. I don't own an Arrma 3S car but believe you can see the servo saver from underneath through a hole in the chassis. If you do the same wiggle on the wheels can you see the servo saver moving? If yes then its the servo saver or servo, if not then its between the saver and the bellcranks. But, as Kpowell911 says, I wouldn't worry about unless its actually affecting how the car drives, most basher cars have lots of play. Quote Link to comment Share on other sites More sharing options...
