Ag100 Posted November 9, 2020 Share Posted November 9, 2020 (edited) Just got the new Losi Lasernut today, not my first one though. Opened up the first one to discover missing screws from the body, shock not fitted correctly, both the rear hinge pins out of place, rounded screw on hinge pin holder and the Steering wouldn’t work, needless to say It was sent back, Make It Build it were great and it was all sorted the next day. Now onto the new one, it’s big!, bigger than I thought, but seems really well put together, there seems to be a few teething issues with these, so have made a few upgrade purchases already: New Steering Servo (Reefs Raw 500) Longer Servo Horn. (Reefs) Full uprated bearing set (RC Bearings Uk) New Exotek Metal Steering assembly M4 Nylock serrated wheel nuts RPM Front and Rear skid plate. I will be stripping down and refilling the shocks and diffs too. I actually prefer to build a kit, but liked this as soon as I saw it, so on the basis it will be getting pretty much a full strip down, it’s basically going to be like a build. Edited November 21, 2020 by Ag100 3 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 9, 2020 Author Share Posted November 9, 2020 Fitted the new Reefs Raw 500 servo (recommended by @.AJ.), the difference really is night and day, the speed is incredible, the standard servo (Spektrum S614) is not really up to the job, this has huge wheels for a 1/10 car. 2 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 10, 2020 Author Share Posted November 10, 2020 (edited) Put fresh 500cst (40wt) Oil in the shocks, and changed the 8 wheel bearings. Edited November 10, 2020 by Ag100 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Ag100 Posted November 10, 2020 Author Popular Post Share Posted November 10, 2020 Decided to remove all the stickers, I prefer the Stealthy look. 7 Quote Link to comment Share on other sites More sharing options...
James.S Posted November 10, 2020 Share Posted November 10, 2020 Looks fantastic de-stickered mate 👍 1 Quote Link to comment Share on other sites More sharing options...
Darren Frosty Posted November 10, 2020 Share Posted November 10, 2020 very Mad Max, I like it. 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted November 10, 2020 Share Posted November 10, 2020 hmmm it does look better without the stickers 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 12, 2020 Author Share Posted November 12, 2020 Took out the Center Diff on the Lasernut today, I wanted to check the oil level, it was virtually empty, so rebuilt with 20000cst oil, and fitted two new Bearings from RC Bearings Uk 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 12, 2020 Author Share Posted November 12, 2020 Onto the rear diff now, this wasn’t to bad with regards to the amount of oil, but I replaced anyway with 10000 cst, and changed the bearings, only issue was the grub screw holding the Center drive cup rounded off, so couldn’t replace the bearing there, will need to order a new one, luckily it’s accessible without taking the hole thing apart again. 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 12, 2020 Author Share Posted November 12, 2020 Next the front diff, better again with the amount of oil, but removed and refilled with 10000 cst Oil, managed to get the Center drive cup off this time, so changed the two bearings in the case too, a quick bench test and all is good. 3 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted November 12, 2020 Share Posted November 12, 2020 Good to see they have included a alloy centre diff case 👍 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 12, 2020 Author Share Posted November 12, 2020 37 minutes ago, .AJ. said: Good to see they have included a alloy centre diff case 👍 Yes, seems well made actually, but as with all RTR, they do need a thorough check over👍 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 12, 2020 Author Share Posted November 12, 2020 Decided to move the receiver, it was stuck to the side of the servo, and it was right in the firing line for any dirt and water, I know it’s waterproof, but though it would be better at the back behind the battery, wiring will be tidied up, but I think it’s much better there. Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 17, 2020 Author Share Posted November 17, 2020 I have now replaced most of the original screws, these just seemed too soft, some were already rounded off before I even tried them, I had to drill and use an easy out on one!. I have replaced with some good quality stainless steel ones from ACCU. 3 Quote Link to comment Share on other sites More sharing options...
Fuzzock Posted November 19, 2020 Share Posted November 19, 2020 Looking great, and getting close to its first blast! Ian... 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Ag100 Posted November 19, 2020 Author Popular Post Share Posted November 19, 2020 A few more bits to do, and can’t use it until Christmas, it’s supposed to be a present😀 1 3 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted November 19, 2020 Share Posted November 19, 2020 Everyday is Christmas round here 😂😂😂 1 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 21, 2020 Author Share Posted November 21, 2020 Painted the little fire extinguisher in the cabin the other day, you can’t really see it, but I think it looks better, want to add a few other scale details to this too. 2 Quote Link to comment Share on other sites More sharing options...
James.S Posted November 21, 2020 Share Posted November 21, 2020 That looks great man! 👍 Like you say, you might not be able to see it all that well with the shell on, but it's all about those small finishing touches 👌 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 24, 2020 Author Share Posted November 24, 2020 Removed the stock bumper and replaced with the TEN-SCTE (LOSB2421) front bumper, should give some better protection. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Ag100 Posted November 25, 2020 Author Popular Post Share Posted November 25, 2020 I added a couple of 25mm esc fans in place of the imitation fan stickers and also a little scale radiator. 4 Quote Link to comment Share on other sites More sharing options...
James.S Posted November 25, 2020 Share Posted November 25, 2020 @Ag100 That looks really cool mate, what an awesome idea 1 Quote Link to comment Share on other sites More sharing options...
tomr Posted November 25, 2020 Share Posted November 25, 2020 Wow ! That looks the dogs mate 👍 Top job 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 25, 2020 Author Share Posted November 25, 2020 Thanks, the fans aren’t serving any purpose other than being there, but happy with how it works. Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted November 25, 2020 Share Posted November 25, 2020 Will the fans be running ? Good idea tho Quote Link to comment Share on other sites More sharing options...
