Moonie7891 Posted April 22, 2020 Share Posted April 22, 2020 (edited) I’ve just got an absima stoke 4s lipo, took it out and within half an hour the steering servo has gone. It also kept going dead, having to turn it off and on again. Any advice and can anyone recommend me a good servo to buy, not sure if they’re different for electric I’ve only ever owned nitro Edited April 22, 2020 by Moonie7891 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted April 23, 2020 Share Posted April 23, 2020 (edited) If it's new i'd not faff around and contact the shop you bought it from. And no, there's no different requirements between nitro and leccie buggies. Edited April 23, 2020 by m4inbrain Quote Link to comment Share on other sites More sharing options...
Moonie7891 Posted April 23, 2020 Author Share Posted April 23, 2020 32 minutes ago, m4inbrain said: If it's new i'd not faff around and contact the shop you bought it from. And no, there's no different requirements between nitro and leccie buggies. Yeah just thinking it may be easier to replace the servo than faff about with returns/warranty atm with everything that’s going on. I have contacted Modelsport by email which can take 72 hours for a reply usually but they’re understaffed atm taking longer. Could have a new servo with me in a day or so. Was more looking for recommendations on a decent servo to purchase and try get to the bottom of the issue with the car having to be turned off and off again every so often Quote Link to comment Share on other sites More sharing options...
Norv Posted April 24, 2020 Share Posted April 24, 2020 check transmitter batteries and replace if they arent full AF, for the servo you could go for: https://www.ebay.co.uk/itm/Savox-Std-Size-Digital-Servo-Metal-Gear-16Kg-6V-SAV-SC-0251MG-UK-STOCK/184004717203?epid=1636690810&hash=item2ad7892a93:g:eXwAAOSwSqZdrxwc or https://www.ebay.co.uk/itm/JX-6221MG-1-8-Truggy-Digital-Steering-Servo-20kg-cm-0-16s-High-Torque-HPI/323727549411?hash=item4b5faa63e3:g:YwoAAOSwbsBXmBWN When you fit it I would check the end points to make sure you stress didnt kill the last one, new RTR models are almost never set up right out of the box Quote Link to comment Share on other sites More sharing options...
