Robbie Berlin
tomzac66
These are a bit of a nightmare, but on with the general servicing and dragging into the 21 century [emoji6]
First job, old hi-tec (low tec) ESC replaced with a couple of mtroniks 30-20 amp tio’s
Props+ gears all greased and lubed 2 new k- series hydra props fitted port starboard.
Made a parallel con for 2 nimhs packs
8600mah testing run times.
Made a washer for the bow thruster running a separate 15amp mtroniks
Separate 6v nimhs to 20amp ESC’s running centre prop works off right hand stick, which allows for slow manoeuvring coupled with bow thruster on left hand stick.
Next job reroute all the cables and tidy up interior then make a battery tray.
