carponizer 2 problem
carp82
Hello ,
I have the carponizer 2 baitboat. When i bought the boat,it  had an lead acid battery 12v ,7.2ah,
my friend replace that battery with lipo. Since then the boat when is out of thw water work great. when i put it into the water work for a few sec and then stop and start flashing the lights. fow 5-10 sec. after that works again for a few seconds.
here is a video  https://www.youtube.com/watch?v=ECxPeNBdat8&t=25s
what is the problem?
Lipo is lithium... Lithium polymer
In layman's terms...
The small box (aka esc) that's connected to the motor will have a max voltage rating...
Its likely to be roughly 12.5 volts... (3s)
You're trying to plug in a 14.4v battery (4s) so your supplying it with too much voltage....
When this happens... Most esc will simply shut off to protect vital components from overheating/shorting out.
So you need a 3s lipo.... Or other 12v battery
I don't know anything about batteries :) my friend has make the change from lead acid to lipo. I will try tommorow with this battery at my local lake
At my bathtub  the bait boat works fine..
I think if  i change my lipo battery (4s) to 3s  as you said  will be ok.
Thank you for your help guys. I appreciated a lot
Edited by carp82
hello again :)
i need little more help. I was looking for lipo battery with 3cell. i saw those 2.
https://hobbyking.com/en_us/zippy-flightmax-8000mah-3s1p-30c-lipo-pack-xt90.html
and https://hobbyking.com/en_us/zippy-compact-6200mah-3s-40c-lipo-pack.html
the first is bigger 8000mah than the second 6200mah. but the first has 30C and the second had 40C. what is this?  if i buy the second battery  with the 40C, is there any problem for my boat?  How can i check that?
Edited by carp82
