Mr Mike Posted September 9, 2016 Share Posted September 9, 2016 I've purchased a Fei Lun FT011 speedboat. What, if anything do i do before taking to the water? I read a couple of bits about before and after runs. Should i seal the boat more than factory spec? Do i need any products....sprays, oils etc. Thanks Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted September 9, 2016 Share Posted September 9, 2016 I'm certainly no expert, but all I did was check end points and make sure nothing was binding, then chucked it in the water. It was recommended I use a marine grease on the prop shaft, but so far it's still greasy. If you're using a dog bone/cvd style coupler, you most likely won't need that, it's only if it's going into a sleeve. Again, that's just the information I've gathered, so don't take it as the be all and end all Hope you enjoy boating, I've found it to be a nice escape and change from the cars. 1 Quote Link to comment Share on other sites More sharing options...
turok007 Posted September 9, 2016 Share Posted September 9, 2016 you could use clear tape around the hatch. but i would just do a couple of runs then check to see if any water gets in first. 1 Quote Link to comment Share on other sites More sharing options...
Mr Mike Posted September 13, 2016 Author Share Posted September 13, 2016 On 09/09/2016 at 19:28, Oh How Original said: I'm certainly no expert, but all I did was check end points and make sure nothing was binding, then chucked it in the water. It was recommended I use a marine grease on the prop shaft, but so far it's still greasy. If you're using a dog bone/cvd style coupler, you most likely won't need that, it's only if it's going into a sleeve. Again, that's just the information I've gathered, so don't take it as the be all and end all Hope you enjoy boating, I've found it to be a nice escape and change from the cars. Thanks for the info. I have just received the boat and it's certainly put together well. Better than i thought actually. The only thing maintenance wise it mentions is a little grease on the prop from time to time. Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted September 13, 2016 Share Posted September 13, 2016 Yep, that's all I was told and mine has actually run well. One thing I would mention is when using it on hot days, keep an eye on the LiPo temps. Mine were pretty high, but on a colder day they were only just warm. No airflow to them makes them warm, mixed with the fact boats are hard on LiPos anyway because you're almost constantly throttling. 1 Quote Link to comment Share on other sites More sharing options...
martin34 Posted September 13, 2016 Share Posted September 13, 2016 Looks very nice mate 1 Quote Link to comment Share on other sites More sharing options...
