Tadas Posted July 3, 2024 Share Posted July 3, 2024 About to replace original motor with Hobbywing 4990 1650kv. Started to think about gearing... What would you guys recommend? I did some calculations: So stock motor with 50/18 gearing should have the same speed as hobbywing with 54/14. Its a bit hard to understand motor power when we only have kv. If i gear them both to run at the same speed - hobbywing one should have way more power just by mechanical advantage? But can we know/calculate motors pure torqe? Quote Link to comment Share on other sites More sharing options...
Tadas Posted July 9, 2024 Share Posted July 9, 2024 Does anyone run their X Maxes with out gear covers? Any issues with that? Quote Link to comment Share on other sites More sharing options...
Maximusbiggus Posted July 17, 2024 Share Posted July 17, 2024 Hey guys, Looking for battery advice... I've decided to buy the Gens Ace D300 charger so will also buy their Lipos too... I can get the bashing series 4s 5000mah 60C for €50 each or 4s 6800mah 120C for €83 each. I'm considering buying 2 pairs of the 5000's which, in my mind, seems to be better value for money but I wonder if there is a reason to choose the larger capacity over the 5000. They're for a brand new, unmodified Xmaxx with standard tyres, not belted. Cheers guys. Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted July 17, 2024 Share Posted July 17, 2024 the higher mah capacity will give a longer runtime also the higher c rating will give more punch and allow more power to be taken out the battery when accelerating your probably better of buying extra 5000mah bats as it will work out cheaper in long run 1 Quote Link to comment Share on other sites More sharing options...
Maximusbiggus Posted July 17, 2024 Share Posted July 17, 2024 Thanks for your reply. Should the 60C 5000mah pack enough punch? What kind of run time might I expect from that 5000mah? Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted July 17, 2024 Share Posted July 17, 2024 no idea on runtime but 60c should give decent punch etc Quote Link to comment Share on other sites More sharing options...
Maximusbiggus Posted July 17, 2024 Share Posted July 17, 2024 Great, thank you. Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted July 17, 2024 Share Posted July 17, 2024 I get about 30 mins on a 10000mah packs, so around half on a 5000mah, but you will get more depending how your driving Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted July 17, 2024 Share Posted July 17, 2024 On 09/07/2024 at 20:19, Tadas said: Does anyone run their X Maxes with out gear covers? Any issues with that? I would worry about stones getting in there and cause damage Quote Link to comment Share on other sites More sharing options...
Maximusbiggus Posted July 17, 2024 Share Posted July 17, 2024 Is it normal for the Xmaxx to feel "notchy" when the power is off and you try roll it forward and back? Like it judders when I roll it. I was expecting it to be smooth and roll more freely... Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted July 17, 2024 Share Posted July 17, 2024 (edited) Its the poles in the motor i think, perfectly normal Edited July 17, 2024 by wolfie1 1 Quote Link to comment Share on other sites More sharing options...
Tug Posted July 17, 2024 Share Posted July 17, 2024 3 hours ago, Maximusbiggus said: Is it normal for the Xmaxx to feel "notchy" when the power is off and you try roll it forward and back? Like it judders when I roll it. I was expecting it to be smooth and roll more freely... That's static torque, it's caused by the magnets in the motor being extremely strong. Perfectly normal. 1 Quote Link to comment Share on other sites More sharing options...
Skinso Posted December 2, 2024 Share Posted December 2, 2024 Has anyone in the UK bought the bug basherbody? Very tempted just for that different look and strength of the proline brute body Quote Link to comment Share on other sites More sharing options...
Partydaz Posted April 10 Share Posted April 10 (edited) Hello 🙂 Does any one use this on there X maxx ? and any downsides to it 🤔, seems it cannot hurt plus little space for the extra bearing anyway but traxxas put nothing in it to support front of spur gear shaft. Been reading / watching videos on X maxx since getting one absorbing all the knowledge on new toy 🤓 and seems 50/50 some folk have trouble with pinion & spur gear stripping and some not. Edited April 10 by Partydaz Quote Link to comment Share on other sites More sharing options...
Tadas Posted April 12 Share Posted April 12 On 10/04/2025 at 08:40, Partydaz said: Hello 🙂 Does any one use this on there X maxx ? and any downsides to it 🤔, seems it cannot hurt plus little space for the extra bearing anyway but traxxas put nothing in it to support front of spur gear shaft. Been reading / watching videos on X maxx since getting one absorbing all the knowledge on new toy 🤓 and seems 50/50 some folk have trouble with pinion & spur gear stripping and some not. im using it - no probs so far 1 Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted April 13 Share Posted April 13 On 10/04/2025 at 07:40, Partydaz said: Hello 🙂 Does any one use this on there X maxx ? and any downsides to it 🤔, seems it cannot hurt plus little space for the extra bearing anyway but traxxas put nothing in it to support front of spur gear shaft. Been reading / watching videos on X maxx since getting one absorbing all the knowledge on new toy 🤓 and seems 50/50 some folk have trouble with pinion & spur gear stripping and some not. Why do you want to remove the Cush Drive? Quote Link to comment Share on other sites More sharing options...
Partydaz Posted April 13 Share Posted April 13 (edited) As far as I can make out this gpm one works with the cush drive, shows in the pics on gpm website it fits with the stock plastic cush drive housing. Not that I wanna get rid of the cush drive for how big this thing is I want all the drive line protection I can get 😄 Checked the GPM website it only shows the metal cush drive so I dunno if it fits stock set up 🤣, guess I'll get on YouTube see whats cracking. Edited April 13 by Partydaz Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 13 Share Posted April 13 (edited) Dont buy that metal cush, its ultra sloppy, the only time i have damaged spur and pinion is when the rubber bit in the cush was really worn, i always run hardened pinion and spur, got them from ali, they were cheap and cannot fault them. For me its diffs, i just have no luck with them, i went through a spate a year anyway ago where i must have changed the rear one 10 times and then it was just fine for about a year, not too long ago i went out and managed to kill every diff on the truck, since i have changed them so far so good……… then you hear of the next person had the truck 4 years and have never replaced a diff, i dont know. But yea i still run mine Edited April 13 by wolfie1 1 Quote Link to comment Share on other sites More sharing options...
Partydaz Posted April 14 Share Posted April 14 (edited) I keep reading horror tales of X Maxxes lasting one run before something going wrong and others run for years without a fresh bearing 😆. I will just use it like the rest of my RCs and see what needs doing when things go pop. I will keep an eye on the cush drive wear and replace when needed as the one in my Maxx is worn down too nothing so I will order up some spares at the same time 😃 Edited April 14 by Partydaz Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 14 Share Posted April 14 Naaa, they are decent trucks and so much fun, i haven't looked back at owning 1 Quote Link to comment Share on other sites More sharing options...
Tadas Posted April 14 Share Posted April 14 On 13/04/2025 at 11:19, Partydaz said: As far as I can make out this gpm one works with the cush drive, shows in the pics on gpm website it fits with the stock plastic cush drive housing. Not that I wanna get rid of the cush drive for how big this thing is I want all the drive line protection I can get 😄 Checked the GPM website it only shows the metal cush drive so I dunno if it fits stock set up 🤣, guess I'll get on YouTube see whats cracking. You use stock cush drive with this. 1 Quote Link to comment Share on other sites More sharing options...
Partydaz Posted April 15 Share Posted April 15 Cheers for the input lads 🙂, got a few bits ordered up from GPM. 1 Quote Link to comment Share on other sites More sharing options...
Partydaz Posted April 22 Share Posted April 22 (edited) Hello 😃, My tyre foams are ****ed been out about 5 times with the X maxx and the foams are shot 🙄, bone dry days no crap got in them just started to fall apart inside the tyre 🙈. I will get round to un gluing the stock set and putting my own foams in and keep them as spares. Don't feel like throwing money at another pair of traxxas kit and the same happing again, so what wheels / tyres do you guys run? and what weight are they as I am trying keep this big ol'thing as light as I can. Edited April 22 by Partydaz Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted April 22 Share Posted April 22 3 hours ago, Partydaz said: Hello 😃, My tyre foams are ****ed been out about 5 times with the X maxx and the foams are shot 🙄, bone dry days no crap got in them just started to fall apart inside the tyre 🙈. I will get round to un gluing the stock set and putting my own foams in and keep them as spares. Don't feel like throwing money at another pair of traxxas kit and the same happing again, so what wheels / tyres do you guys run? and what weight are they as I am trying keep this big ol'thing as light as I can. I run Louise Uphill Xs. I tape the holes on all my RCs tyres 1 Quote Link to comment Share on other sites More sharing options...
Partydaz Posted Tuesday at 12:29 Share Posted Tuesday at 12:29 Ohhh good few of these Louise wheels 😀 I'll have a proper look when I get home, are they a direct fit no adaptors or anything needed 🤔. Quote Link to comment Share on other sites More sharing options...
