Baja5B Posted February 27, 2012 Share Posted February 27, 2012 spur gear and pinion gears are fine, fitted a stronger 8000RPM clutch spring, after putting that on I was reving to half revs before the wheels starting spinning and travelling very slowly, could it be that the clutch spring is very tight and will it weaken over time and sort the problem out? is this the problem or is it somthing else? thanks Quote Link to comment Share on other sites More sharing options...
stebro Posted February 27, 2012 Share Posted February 27, 2012 (edited) Could be a dog bone pin, Busted gears, rounded wheel hex or broken clutch. Best way is have a quick look at what doesn't move when revved up. Or it could just be you not givibg it enough revs to get it moving Edited February 27, 2012 by stebro Quote Link to comment Share on other sites More sharing options...
norcoforever Posted February 27, 2012 Share Posted February 27, 2012 have you only revved it to half way as on a stock engine thats roughly when the 8000k clutch kicks in or is this at full throttle? Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 Could be a dog bone pin, Busted gears, rounded wheel hex or broken clutch. Best way is have a quick look at what doesn't move when revved up. Or it could just be you not givibg it enough revs to get it moving the gears are all fine, wheels arent rounded or the hexes broken, must it be the clutch? so nothing to do with the new spring? and what is the dog bone pin and where is it :/ please? and no i gave it a good 5-10secs on full revs and it was only travelling very slowly have you only revved it to half way as on a stock engine thats roughly when the 8000k clutch kicks in or is this at full throttle? i tryed full throttle for a good 5-10 secs Quote Link to comment Share on other sites More sharing options...
stebro Posted February 27, 2012 Share Posted February 27, 2012 Dog bone pin it the pins that go through the dogbones ( driveshafts ) these can break. If it moving slowly i would say the clutch isn't engageing right, i.e it isn't opening up correctly to give full drive Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 Dog bone pin it the pins that go through the dogbones ( driveshafts ) these can break. If it moving slowly i would say the clutch isn't engageing right, i.e it isn't opening up correctly to give full drive does that mean that it is the spring as the sping is very tight and causing it not to be able to open up? Quote Link to comment Share on other sites More sharing options...
stebro Posted February 27, 2012 Share Posted February 27, 2012 No really. Could be something stopping the clutch from opening. The clutch bolts may have not got a washer in the right place. I have a 9500 rpm spring so thats real tight but i have no problems moving Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 No really. Could be something stopping the clutch from opening. The clutch bolts may have not got a washer in the right place. I have a 9500 rpm spring so thats real tight but i have no problems moving i really havent got a clue tbh cos the bolts wen back on the way they came of and there was no change but thanks anyway:) Quote Link to comment Share on other sites More sharing options...
JonnyCooper Posted February 27, 2012 Share Posted February 27, 2012 have you only revved it to half way as on a stock engine thats roughly when the 8000k clutch kicks in or is this at full throttle? The car is gunna start moving before half throttle though isnt it. Quote Link to comment Share on other sites More sharing options...
norcoforever Posted February 27, 2012 Share Posted February 27, 2012 The car is gunna start moving before half throttle though isnt it. not a lot on an 8000k clutch how old is the clutch bell? if its worn the clutch may be slipping and have you checked the clutch pads aren't contaminated with any grease or oil?? Quote Link to comment Share on other sites More sharing options...
stebro Posted February 27, 2012 Share Posted February 27, 2012 i really havent got a clue tbh cos the bolts wen back on the way they came of and there was no change but thanks anyway:) Is clutch in good condition. Plenty of pad left Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 Is clutch in good condition. Plenty of pad left ah tht could be it, the clutch has never been replaced and the cars a good 4 years old. i really dont know what im looking for :/ please could you send me a link of what i need? thanks alot Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 not a lot on an 8000k clutch how old is the clutch bell? if its worn the clutch may be slipping and have you checked the clutch pads aren't contaminated with any grease or oil?? would it be the clutch bell or the pads? once again i dont know what im looking for :/ , please could you send me a link of what i need? Quote Link to comment Share on other sites More sharing options...
stebro Posted February 27, 2012 Share Posted February 27, 2012 The clutch pads should be nice and meaty like this Quote Link to comment Share on other sites More sharing options...
norcoforever Posted February 27, 2012 Share Posted February 27, 2012 would it be the clutch bell or the pads? once again i dont know what im looking for :/ , please could you send me a link of what i need? it could be either but the parts would be http://www.mmrlargescale.co.uk/acatalog/RCSK15448.html http://www.mmrlargescale.co.uk/acatalog/RCSKCBK.html your best bet is to take the clutch and clutch bell off and take photos of both if you upload them on here someone will be able to tell you whats wrong my feeling is its the clutch shoes Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 The clutch pads should be nice and meaty like this it could be either but the parts would be http://www.mmrlarges.../RCSK15448.html http://www.mmrlarges...og/RCSKCBK.html your best bet is to take the clutch and clutch bell off and take photos of both if you upload them on here someone will be able to tell you whats wrong my feeling is its the clutch shoes I think thts it because when i took it off the other day I dont think it was thick round the edge, if that is the case, do you recon that will be the problem? and is the only way to fix this to buy a whole new one? Quote Link to comment Share on other sites More sharing options...
norcoforever Posted February 27, 2012 Share Posted February 27, 2012 i think you have to not certain tbh out of a split like mmr they are Quote Link to comment Share on other sites More sharing options...
stebro Posted February 27, 2012 Share Posted February 27, 2012 If there is no meat left on the pads then you do need a new 1 and this could cause it to slip. Get it off te baja and post a picture Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 27, 2012 Author Share Posted February 27, 2012 i think you have to not certain tbh out of a split like mmr they are Quote Link to comment Share on other sites More sharing options...
Baja5B Posted February 28, 2012 Author Share Posted February 28, 2012 (edited) it could be either but the parts would be http://www.mmrlarges.../RCSK15448.html http://www.mmrlarges...og/RCSKCBK.html your best bet is to take the clutch and clutch bell off and take photos of both if you upload them on here someone will be able to tell you whats wrong my feeling is its the clutch shoes that website is good but the clutch is out of stock and as its from the kit, ive rung and they won't get another in for about two weeks, would this be ok? http://www.ebay.co.u...=item3a64f6d755 its not a copy or any thing is it? it won't be rubbish will it? thanks for your help some how the clutch pads dont look as meaty? Edited February 28, 2012 by Baja5B Quote Link to comment Share on other sites More sharing options...
flash22 Posted February 28, 2012 Share Posted February 28, 2012 try freeprawnracing.com ordered quite a bit recently without problems and quick delivery too http://www.freeprawnracing.co.uk/petrol-parts/clutch-parts/ Quote Link to comment Share on other sites More sharing options...
stebro Posted February 28, 2012 Share Posted February 28, 2012 Here is a clutch http://www.msuk-forum.co.uk/topic/133966-large-scale-bits-baja-ftx-etc-updated-25802/page__fromsearch__1 Quote Link to comment Share on other sites More sharing options...
Pumpkin Pete Posted April 11 Share Posted April 11 Wheels turn freely off ground once on ground they don't move Quote Link to comment Share on other sites More sharing options...
Dun2504 Posted April 15 Share Posted April 15 On 28/02/2012 at 19:14, Baja5B said: that website is good but the clutch is out of stock and as its from the kit, ive rung and they won't get another in for about two weeks, would this be ok? http://www.ebay.co.u...=item3a64f6d755 its not a copy or any thing is it? it won't be rubbish will it? thanks for your help some how the clutch pads dont look as meaty? Try rcmodelz They stock most baja bits and are quick . clutch should be about £20/30 . shouldn't be a problem to change the shoes. Just get them the right way round(there is usually an arrow for direction) Quote Link to comment Share on other sites More sharing options...
Dun2504 Posted April 15 Share Posted April 15 On 11/04/2025 at 18:39, Pumpkin Pete said: Wheels turn freely off ground once on ground they don't move Is this the same thread ? or a different problem ? Quote Link to comment Share on other sites More sharing options...
