stretch
9 hours ago, Rustic Ade said:
Did you need to mod it much to accommodate the shocks?
I used axial bushings at top (part Z-AXA1356) and then at the bottom some longer screws with 4 x washers at the front and 2 X at the rear.  The washers are to push the lower end away from the arms.
I think I had to cut a smidge out of the body at the rear as well to make sure the springs were cleared.
Interesting, it's coped with most things I've thrown at it or thrown it at, but the shocks do take some stick.
Put the Taylor RC rear uprights and ball joints on the Baja today.
First set back with Taylor RC parts though, put the axle through the upright, put the hex on but the retaining pin wouldn't go in, like it was off by a thousand of an inch or something.
Was a bit stumped but ever so slightly filed down the "ring" on the back of hex and the pin dropped in.
Makes me wonder if it is supposed to be like that, certainly doesn't need shimming any like it did with the stock set up.
Edited by markymarky
5 hours ago, Mack1 said:
Bought the TRX-4 on holiday with me this week. Staying at Pembrey Country Park south Wales so have been scoping out different areas to play. Found a real nice spot not far away from us so have been busy playing.
Love the look of that crawler 😊 but it's to clean! it needs some mud action all up in its business 😛.
It's got plenty of dust and sand all over it. Not rained really for a week now. Forecast tomorrow though, so we will see what happens 😆
Got the electronics in on this lcg build.
Started chopping some of the body. It's probably going to need a chunk off the front because of the bumper I borrowed from another build.
I gave it a little test and it's pretty good.
The Rhino esc and motor has very smooth low down and plenty of power.
IMG_20240612_181543 IMG_20240612_181605 IMG_20240612_181730
Couldn't sleep last night due to sleeping in the day (I was dead to the world) so done the diffs on my hyper vse. Inside them was shocking. Would of been better off leaving them empty and letting you do them yourself. All 3 fully cleaned out of the grease and filled with oil 15/50/7. Also reglued the tyres
 Hopefully round 2 will be much better now 🙏
On 12/06/2024 at 19:14, steephill said:
Here's a short video of the rhino motor spinning away.
Very smooth!
Started cleaning/striping the mog after yesterday's event only to find one of my 2 run old tyres is ripped. The inner wheel is heavily scored as well so no idea what it got caught on 🫣
  • Confused 2
  • Sad 4
25 minutes ago, Lone-wolf said:
looking good steephill, interested to see how it pans out, i must get round to doing the new shell (Texan) for my Element once i get running problem sorted
Thanks mate 👍
I've just given it another coat of flat clear. And some black inside.
I'll get some better pictures when I've got the window masks off.
I ordered another Texan clear body yesterday. By far the best value cab only body. I prefer them over the jconcepts and proline offerings.
