stretch
changed out the stock radio for my preferred one, found the 4s used back in my Xmaxx days and they fit in the battery and time for a pinion change, 15t me thinks, 17t will only end in an expensive fix. 🤪
Finally fitted the new rear drive shaft on the UDR even added little boot thingy to hold the grease in even adds a little scale touch to it me thinks 😃. It'll probably fly off in the first 5 mins but at least I tried 😄. I really need to give this truck a clean 🫣IMG_20241114_175734.thumb.jpg.3a964364378822a90903500553c56cfa.jpg
5 hours ago, Partydaz said:
Took the UDR out around the quarry after work and some local yoofs have made a ramp on the little hill I jump over 😄 perfect for RC trucks.
Have not missed cleaning this thing over summer, winter time brings the muck 😭
I love the udr.  Don't use mine as much as the crawlers but it's still my favourite to use and work on.
How do you find the ddf 350, tempted to get one but don't know if I could get my head round all the settings I could change,😕
Edited by wombat
Spell checker
1 hour ago, bunnie said:
Done a few changes and stripped down all 3 diffs on my maverick Quantum truck before i even used it as I read they come empty. I've never had to do diffs on a brand new rc car unless I've built it from kit form
both front and rear diff were like this
Centre diff
Threadlocked the driver cups as they are known to come lose
Added my ddf-350 radio gear
Added body retainer clips
Quick change of the settings and it's now ready to go 🙏
The other reason they come slack is the pinions aren't held right up against the bearing on the inside when the cup is put on and tightened on the outside so there isint any forward and back movement, only result i have had with mine was doing this before the diff itself is put in
Well not exactly model based but lipo based, got these lovely lipos delivered today and then immediately cut the plugs off and soldered on xt90, these ones were on special but the xt90 ones werent so saved myself around £60, £50 i suppose if you count the new connectors, also changed all the rest of my 3s lipos to xt90 except for the traxxas ones
Edited by wolfie1
It's quite easy once you get used to it. Feels bit slow moving through the menus and inputting model names can be a pain but if you ever used an old Nokia mobile before it'll all come back to you that's kinda what it feels like to use 😀.
Edited by Partydaz
Best radio gear I've had so far and I've had both budget and top end setups. The arrangement of certain options could be better but you get used to it so it's not an issue. Only down side is it can only store 10 models but as they so cheap I ended up buying another so I now have 2.
I made sure mine was fully in place when I took the diffs out so there is no play but thanks for the heads up
On 17/11/2024 at 15:15, MrCake said:
Got it muddy!  First winter run for the DR8 and I forgot how hopeless it was traction wise with the stock tyres 🤣. Think I looked at 6s Mojave wheels before but never got them.
Got Mojave wheels/tyres on my DR8...Night and day difference from the stock ones ! 👍
14 hours ago, TommyC said:
So this is happening already…
Ahhhhh its a cute little little maxx 😃 I need! one of these they look ace 😄. Do they seem as beefy as the bigger brothers?
I couldn’t say as I don’t own the bigger ones. It does look like an absolute tank though. Definitely a lot beefier than the groms. In fact, there’s no comparison really!
There’s an optional centre diff available for them that I’ve got on pre order too. I’m 3d printing some bits to make the conversion nice and tidy which I’m hoping to finish this evening.
Edited by TommyC
Got any photos of how it looks? They are taller and a bit narrower from Google dimensions to stock.
Size wise they are just about the same, it's just the tread pattern that is more open. I've seen someone on here ( think it was tomr ) who actually cut some of the blocks out of the standard tyres...far too tedious for me so I spent some more money!! 🤣
  • Haha 2
How ironic. Ive got exactly the same system for mine! Well truth be told Ive got both the 3300kv combo and the 5400kv one. Not sure which one to us. You going 3S?
Bit of shock tuning for the Kagama, I think it's set up for big jumps with 1000cps shock oils so going use the off road tuning recommendations by Corally which are in the manual get it handle even better 🙂.
And I've only just realised what the holes on the stand are for after 3 years of having it, it has been kept propping up RC cars in that time so thats my excuse 🙃
Got burner on full blast tonight as it's cold in here and Mog is happy about it 😊.
