stretch
I think they have 4x4 fun days from time to time we kept coming across bits of old land rovers and Honda's 😆, I best not turn up when an event is on or me and my tiny truck will get squished by a lifted v8 landy 😅
  • Haha 2
Finally pulled the Reedy ESC out of the gatekeeper and put a 1080 in, now just waiting for the 5 slot 19 t 540 to arrive, this rig is less element and more aftermarket parts these days, i pulled the 1080 from the injora rock buggy as its not getting used much and stuffed a 1060 in the rock buggy
Well yesterday, i was a cretin when i was out with the xmaxx…… the pinion came slack so put it back on with some loctite and continued my fun, came home cleaned everything up put batteries on charge and then decided too make sure the pinion was on properly, so bit of heat to remove the grub screw, out it comes pinion was stuck on the shaft, stupidly i used a pry bar to attempt to remove the pinion and snapped the shaft off the motor, so now a new motor incoming 🥲🤫
  • Sad 4
1 hour ago, SimplyChunk said:
Waited......
......on some good weather so @Skyesgaming and I can start to spray our DT-03s
Also sanded down our edges in anticipation 😄
Can you not make yourselves a little spray booth in the kitchen using a large cardboard box, i have done that in the past
2 hours ago, Tadas said:
Upgraded driveshafts and center driveshaft to metal. Son is driving on some fine gravel that eats up all plastic spinning things 😄
Which brand did you go with for the metal drive shafts? , my little revo has lots of wobble on the rear wheels because the plastic ones have loads of play in them now and don't fancy putting plastic drive shafts back on 😬.
I went with original traxxas parts:
