How to repair a Fiberglass fuselage..
What you'll need..
Dremmel with a thin cutting disc ,thin CA glue, thin carbon tow , scissers , P38 filler , sand paper (rough and fine)..
Check over the fuse and find all the cracks (mark them off ,if you wish)..
Using the cutting disc cut slots/grooves into the fuse..
Cut the carbon tow up into lenghts long enough to over lap the groove's ,
place the carbon tow into the grooves and wick ( let the glue run down the carbon tow ) with the CA glue..
mind you don't stick your fingers to the fuse :rolleyes:
CA glue over the crackes as well..
Leave to dry..
Sand over the Carbon tow,to remove the over lap on the grooves..
Wipe area clean to remove any dust.. Mix up the P38..
Apply over where you've Carbon towed the fuse..
13.Leave the P38 to dry/harden, then it's back to the sanding again..
Use the rougher sand paper first then the finer for a smoother finish..
If you find any small holes ,
fill them in with some more P38 and sand smooth..
Once all is finished you can then spray paint your fuse..
Sean..
