advice please my ansmann virus 2 was running perfect til yesterday.it starts virtually straight away however it seems as if the brakes are on whwn it stands still. when you give it throttle it runs fine but when you back off the throttle it stops as if the brakes are applied. if i stop the engine and try to push the vehicle again its as if the brakes are applied and is hard to push both forward and back. however if i turn off transmitter and receiver the car runs free
is this clutch problem
Started by ansmann1, Sep 07 2010 07:38 PM
3 replies to this topic
#1
Posted 07 September 2010 - 07:38 PM
#2
Posted 07 September 2010 - 07:43 PM
you just need to adjust the trottle trim on your transmiter mate
#3
Posted 07 September 2010 - 07:46 PM
i wouldnt adjust the trim if the throttle runs fine, i would adjust the brake linkage and just loosen it off till it runs free with the servo at the idle position then fine tune it while running to make sure the brakes work
#4
Posted 07 September 2010 - 08:38 PM
cheers will try this tomozz
Join us on Facebook
