first savage
#1
Posted 03 September 2010 - 04:35 AM
just bought my first savage 25 and got it home has lots of alloy but think it needs a tank protector or alloy tank the chassis plates have integy on them so do i need an integy tank protector? also has low profile tyres on so want something for dirt use any recommendations please will try and get a pic on later
#2
Posted 03 September 2010 - 08:33 AM
I'd get rid of most of the alloy and stick with plastic mate. Alloy breaks/bends unlike plastic which flexs. You can put any tank protector on it. Dint bother with alloy one they leak.
Savage 25 has 14mm wheel hexs so any 14mm wheels will fit.
Get a wheelie bar and engine/roll cage from a savage x and strengthen up the savage. Parts are cheap on eBay and all bits from all the savage range will fit yours.
#3
Posted 03 September 2010 - 09:16 AM
would love to see pics of the bling machine
#4
Posted 03 September 2010 - 01:30 PM
#5
Posted 03 September 2010 - 02:51 PM
just got some proline velocity wheels and proline bow tie 3.8" 40 series off road tires on advice from local model shop says it improves handling just notices that it has anti sway bars front and rear too
#6
Posted 03 September 2010 - 03:52 PM
hope these pics work first time doing it
#7
Posted 03 September 2010 - 09:20 PM
#8
Posted 03 September 2010 - 09:21 PM
Id get better shocks for it (cen genesis are good and i have them on mine, not alloy tho,lol), id also put the plastic roll cage/engine protector from a savage x aswell. Yours looks nice tho
#9
Posted 03 September 2010 - 10:05 PM
#10
Posted 03 September 2010 - 11:03 PM
I think I'm right in saying the force engines are bigger in size, as in might not fit. Don't get a hpi xl engine 5.9 I heard lots of bad things about them going wrong from the start.
The hpi k4.6 is a good engine, they do a f4.6 aswell but the k4.6 is better.
I have had the os max vg30 engine and I currently has a lrp z30r which has 4.12 horse power and is bloody fast, lol most 21 to 28 size engines will fit straight on the savage mate, there's loads out there on eBay just depends on your budget and if you want it too go like a rocket or not.
I would personally toughened it up with heavy duty parts if it hasn't been done already ( hd diff cups, dog bones, bulletproof diffs from a savage xl/flux, also check too see if the steering servo is standard ( hpi sf1, hpi sf2) as you will want a metal geared high torque servo for the steering.
No gaskets on the engine head just a head button ( the bit right underneath the cooling head that the glow plug screws into, they also have head shims ( different thickness washers for compression)
If it's not starting maybe a good idea too post why and what you did too it?? Have you flooded the engine?? Dd you prime the engine?? Have you messed with the carb screws ect??
Hope that helps
#11
Posted 04 September 2010 - 09:28 AM
There's nothing wrong with alloy parts, so long as they're used right. Alloy wheel hubs are better as they need to be strong, but you need suspension arms to bend in a crash, so plastic.
#12
Posted 04 September 2010 - 09:39 PM
i have used the instructions that came with engine and just fine tuned the high speed needle and now runs fine and about 230f do i need to adjust the low speed needle as it accelorates ok but no wheelies!! been told to leave the mid needle well alone
#13
Posted 05 September 2010 - 09:04 AM
#14
Posted 05 September 2010 - 09:10 AM
#15
Posted 05 September 2010 - 02:39 PM
plumber dave, on 05 September 2010 - 09:10 AM, said:
dual disks help alot, you should get those.
as for the linkage, if you have ever had problems with the throttle linkage then go ahead and get it.
Join us on Facebook
