CRC are offering a conversion for the Losi XXX-T to turn them into a SC Truck. The set converts most all XXX-T truck kits from Team Losi, including the Desert Truck & XXX-T CR utilizing carbon fiber chassis extensions that allow you to use your stock rear bottom plate. Using the stock rear bottom plate makes converting any XXX-T a breeze because there will be no complications with the rear arm mounts, transmissions, etc not matching up. RTR’s, MF 1’s, MF 2’s, Desert Trucks, and the newest XXX-T CR’s can all be converted using this setup, however the CR will require you to replace the quick change hubs and axles over to standard type axles.
Source: Red RC
