windydaniel Posted February 22, 2010 Share Posted February 22, 2010 does anyone know what the ratings of the different colours are for the jaco foam tyres i have just ordered 1x Jaco Low Profile Pink Foam Rear Tires and 1x Jaco Low Profile Purple Foam Front Tires just wanted to know i i have ordered to hard or to soft as i cannot find a colour code anywhere these are just for general road running any ideas? thanks Quote Link to comment Share on other sites More sharing options...
CerebalSymphonY Posted February 26, 2010 Share Posted February 26, 2010 (edited) Here is some Empirical information don't sue if there are any errors. The hardness of materials is most commonly measured by the Shore Durometer test. This method measures the resistance of foam toward indentation and provides a hardness value. A Shore Durometer is the international standard for measuring the hardness of materials. The symbol for shore coincides with that of degrees. In reference to foam tires, the lower the shore rating, the softer the tire is thus yielding more traction. The higher the shore rating, the firmer the tire is thus yielding less rolling resistance and more speed. =================================== Jaco.. 30-Pink 30-Yellow 35-Double Pink 40-Purple 45-Double Purple 40/50-Orange/Purple 35/45-Double Pink/Orange <P class=catdesc>1/12th Tire Guide This is a quick reference list for tire durometers and applications for any 1/12th car Black - 40S: Special tire for insane traction carpet tracks. Does not get gummy like Purple. If you don't have insane traction you car will push with these. Purple - 40S: Good for medium bite conditions in stock racing. This compound is getting popular again because of Jack the Gripper traction compound. With Jack Purples do not get too sticky. Lilac - 37S: Great front tire for stock carpet or if dbl. pink is too much steering. Double Pink - 35S: This is the standard front tire for carpet in all classes. Its is used front and rear for 19T and Mod carpet and front and rear in all classes on asphalt. Grey - 35S: This is a low natural rubber compound. It is just as hard as dbl. pink but it had FAR LESS traction. It is used to free up the rear of stock powered carpet cars for more efficiency and corner speed. This is the old standard rear carpet tire, most stock carpet racers use the softer yellow compound now for more forward grip. Magenta - 32S: Its softer than dbl pink so if you need more steering than dbl. pink use these up front. If you need more rear traction than dbl. pink use these in the rear. Pink - 30S: This tire is used in mod 1/12th on carpet and asphalt if the traction is low. If the traction is high it will lock in the rear of the car and make it push. Yellow - 30S: This is a low natural rubber compound. It is the standard rear tire for Stock racing. It is used to free up the rear of stock powered carpet cars for more efficiency and corner speed. White - 25S: This is a low natural rubber compound. It was the standard rear tire for 1/10th on road carpet racing. Its a little softer than yellow. Parma.. 35-Magenta 35/55-Cyan 40-Purple 40/55-Plaid TRC.. 25-White 26-Platinum 28-Green 29-Gray 30-Pink 30/35-Granite 32-Brown 35-Magenta 36-Double Pink 34/45-Cyan 36-Black 37-Tan 39-Blue 40-Purple 42-Lime 40/45-Plaid 45-Double Purple 46-Red 50-Double Blue 55-Orange ----------------------------------------------------------------- 1. list: jaco synthetic rubber black 40 shore gray 35 shore yellow 30 sh white 25 JACO -nature rubber purple 40 shore lilac 38 sh dbl pink/orange 35/45 shore double pink 35 shore magenta 32 shore pink 30 shore ------------------------------------------------------------------------------ 2.list CRC Standard Front Magenta - 36-40 shore "soft purples". High grip, long life. Part of the pink/purple family of rubber. Great for 1/12th modified or asphalt. Black - Long wear, high grip exotic racing rubber. Red - Med-Firm 40 shore. Exotic, super long wear, med. grip, high rubber content racing foam. For front tires on asphalt. Not for carpet. Purple - Firm 45 shore. Exotic, long wear, high grip, high rubber content racing foam. Dual Compound Magenta/Orange - Med. 35 - 39 shore. Exotic, long wear, high grip, high rubber content racing foam. Purple/Orange - Firm 45 shore. Exotic, long wear, high grip, high rubber content racing foam. Rear White - Med. wear, high grip exotic racing rubber. Green -30 shore Good old American foam rubber. Less expensive, good grip on carpet, but more wear than the pink/magenta family and more wear than the white/grey family. Pink - 30-33 shore. High grip, long wear. The traction leader for rear grip. Great for asphalt.Wears like iron with great grip. Grey - Long wear, high grip exotic racing rubber. Magenta - 34 - 38 shore. High grip, long wear. Same family as pink, but firmer. Great forasphalt and carept. Wears like iron with great grip. Pro Cut - Larger diameter Front Grey - Softer than black compound for more steering, gets less stickey than Magenta or Purple. Black - Firm shore, long-wear, high grip, less rubber content, less tacky on high bite tracks. Purple - Firm shore, long-wear, high grip, high rubber content. Magenta - Medium shore, long-wear, high grip, high rubber content. Rear White - Soft shore, long-wear, high grip, less rubber content, less tacky on high grip. White compound is very soft and will chunk when trued very small Grey - Medium shore, long-wear, high grip, less rubber content, less tacky on high grip tracks. Pink - Soft shore, long-wear, high grip, high rubber content. Magenta - Medium shore, long-wear, high grip, high rubber content. Jaco Standard Front Green – Medium, standard Pink – Medium-Soft, low wear Double pink – Medium, low wear Purple – Medium-Firm, low wear Rear Green – Medium, standard Pink – Medium-Soft, low wear Gray – Medium, low wear White – Medium-Firm, low wear Prism – Larger diameter Front Magenta – 32 Double Pink – 35 Lilac – 38 Purple – 40 Black – 40 Rear White – 25 Yellow – 30 Gray – 35 Pink – 30 Magenta - 32 Parma --Standard White – 25 Pink – 30 Black – 35 Violet – 35/40 Purple – 40 Pro 38 – Larger diameter Grey – 30 Magenta – 37 Purple – 42 ====================================== Good Info on Foams Nitro Based ================================= Edited March 2, 2010 by CerebalSymphonY Quote Link to comment Share on other sites More sharing options...
windydaniel Posted February 26, 2010 Author Share Posted February 26, 2010 Thanks CerebalSymphonY thats spot on info!! Quote Link to comment Share on other sites More sharing options...
