* * * * * 1 votes
Schumacher CAT SX2
13 replies to this topic
#1 Garry
    Racers do it 5mins at a time!
  • Forum Staff
  • 20,934 posts
  • Gender:Male
Posted 08 February 2010 - 12:50 PM
Quote
Posted Image
Following on from the successful Cat SX, Schumacher introduces the new Cat SX2. Now even stronger and more durable than ever before the new 4wd buggy is fitted with all new large capacity 13mm big bore shocks and high downforce max sized rear wing. Claiming to be the best balanced car in its class, with optimum weight distribution due to its new stick pack lipo layout chassis and near centre motor position. An ultra efficient transmission makes the CAT SX2 incredibly quick off the line and offers awesome straight line speeds.
Posted Image
Features
- 3 belt transmission with efficient low tension belts running on large size CNC machined pulleys.
- Adjustable internal transmission ratio (2.2, 2.4, or 2.6:1) to optimise ratio for brushed or brushless motors.
- Motor rotates the same direction as the wheels creating a car with superb jumping responsiveness and no torque steer effect as is common with shaft drive cars.
- Super free ball diffs with silicone nitride balls, pro spec thrust bearing, and steel diff outputs.
- Strong steel universal joint driveshafts.
- Smooth twin pad slipper clutch with easy access adjustment running on a New tougher 5mm black spur gear.
- Unique clamp motor mount to fine tune weight distribution, and allow motor changes without affecting gear mesh.
- Industry standard wheel fittings.
- Layshaft or front one way Speed Secret option.
- Overdrive front pulley Speed Secret option.
- Optimum weight distribution with stick pack lipo layout.
- New 2.5mm aerospace grade carbon fibre chassis and top deck.
- Horizontally split transmission housings for ease of maintenance and diff access.
- Ultra narrow chassis design to minimise grounding on roll.
- New Stronger front & rear wishbones.
- New Stronger 4mm front pivot block screw.
- New Lighter plastic eccentric housings for adjustment of belt tension and diff height.
- Rigid servo mount directly onto transmission housing for precise steering.
- Dirt protected with tight fitting body and undertray.
- O ring wing mount system to avoid crash damage.
- New Max sized rear wing.
- Class leading suspension geometry with durable components and a range of optional alloy parts, offering adjustments to set up your CAT SX2 to any track conditions.
- New more durable plastic pivot block system with the ability to adjust track width and toe in/toe out.
- Adjustable rear roll centres, inboard toe-in/toe-out, anti squat and track width using optional alloy block Speed Secret parts.
- Adjustable front roll centres, inboard toe-in/toe-out, track width and rake angle using optional alloy block Speed Secret parts.
- New Pro spec big bore shocks with titanium nitride shafts, CNC machined pistons with recessed ‘e’clips, threaded collars, twin O ring sealing and diaphragm volume compensation.
- Strong and rigid 4mm carbon fibre shock brackets.
- New lighter plastic steering arms.
S1 Specification includes:
- Tough S1 composite chassis and top deck with optimised flex.
- Tough S1 composite shock towers.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Source: Red RC
#2 Euphoria
    Veteran Member
  • MSUK Supporter
  • 3,195 posts
  • Gender:Male
Posted 08 February 2010 - 12:55 PM
That looks awesome!
#3 ste77_2008
    Veteran Member
  • Banned
  • 3,579 posts
  • Gender:Male
  • RC Cars:MCD racerunner v3
Posted 08 February 2010 - 12:59 PM
that`ll be quick, what shell does it have.
#4 Guns
    The Greatest.....
  • Members
  • 13,127 posts
  • Gender:Male
  • RC Cars:Not Enough Space Now, See Sig.
Posted 08 February 2010 - 03:19 PM
looks great from the side profile, lovely low COG
#5 kwik-kid
    MSUK Regular
  • MSUK Supporter
  • 951 posts
  • Gender:Male
  • RC Cars:none :( donate please :D
Posted 08 February 2010 - 04:38 PM
isnt this just the previous cat and the mi4 merged together?
durango and pred are better in my opinion...
#6 Garry
  • Forum Staff
  • 20,934 posts
  • Gender:Male
Posted 08 February 2010 - 06:51 PM
No, its the SX with all the updated team parts that were developed last year like big bore shocks, slipper clutch, top deck, wishbones etc.
Preds are pretty poor on anything but a flat track, and the Durango is around £150 more than this. :P
#7 Matt_N
    junk food addict
  • MSUK Supporter
  • 2,136 posts
  • Gender:Male
  • RC Cars:SC10FT, B4, TRF416x, XR311, Academy SP3, V-One S, 8ight-e, Bullet Flux ST, Ultima DB, Savage
Posted 08 February 2010 - 10:24 PM
I think this looks pretty sweet, quite tempted by it :P
Matt
#8 babylon
    MSUK Regular
  • Members
  • 551 posts
  • Gender:Male
  • RC Cars:Hong Nor CRT Pro,Kyosho Inferno Kanai Edition,RC10 T2 x 2,E-Revo
Posted 09 February 2010 - 01:03 AM
Isn't it more officiant to cut down the amount of belts you use, More belts is more friction is it not.
#9 Garry
  • Forum Staff
  • 20,934 posts
  • Gender:Male
Posted 09 February 2010 - 03:40 PM
In theory, yesh, but then you're really compromised by where the electrics can go inside the car with less belts. With off-road racing, there isn't a motor limit, so efficiency of drivetrains aren't that important when you can just fit a quicker motor. Its a better idea to get the heaviest parts of the car (motor, battery pack, electrics) as close to the middle and as low down as possible, then fit everything around it.
Thats pretty unique for electric off-road though, most belt drive nitro racing touring cars are 3 belt, as is the legendary Losi XX4 4wd electric buggy.
#10 R46
    nitro hero
  • Members
  • 6,314 posts
  • Gender:Male
  • RC Cars:too many for this space here....
Posted 10 February 2010 - 10:53 AM
likes very much :good:
#11 paul2304
    Veteran Member
  • Members
  • 2,196 posts
  • Gender:Male
  • RC Cars:None At the Mo
Posted 10 February 2010 - 11:44 AM
my rc life started out with a CAT 2000 many moons ago , would love to get my hands on one again
#12 Nathanio
    MSUK Regular
  • Members
  • 1,223 posts
  • Gender:Male
  • RC Cars:Hyper 7e to be completed and Traxxas E-Revo VXL
Posted 10 February 2010 - 12:51 PM
That just looks quick stood still. The adage of what looks right goes right applies here me thinks!
#13 daveTheRave
    Just Registered
  • Members
  • Pip
  • 22 posts
  • Gender:Male
  • RC Cars:Schumacher Cat SX
Posted 11 February 2010 - 08:55 AM
DOH!!
how annoying is that, I just bought a cat sx kit around 2 weeks ago.
Is it possible to upgrade the kit I have to the sx 2 spec or is it a totally different kit?
It looks quite similar..
#14 Garry
  • Forum Staff
  • 20,934 posts
  • Gender:Male
Posted 11 February 2010 - 05:31 PM
I don't think there will be an upgrade kit, but you can certainly buy all the new parts as they'll fit either the SX or SX2.
Modelsport UK
