TKR5304
53HRA
NB48.3 New Features:
  • Completely redesigned suspension geometry
  • Revised chassis
  • New front arms
  • New rear arms
  • New front and rear 7075 CNC aluminum shock towers
  • New extra long shocks for increased suspension travel
  • New tapered 4 x 1.8mm shock pistons
  • New clamping spring perches with captured shock boots
  • New rear hubs
  • New trailing front spindles and spindle carriers
  • New V2 hinge pin braces and inserts
  • Low profile wing mount
  • Revised bumper for increased ground clearance
  • New straight turnbuckle rod ends
  • New left and right hand threaded shock mount screws
  • New easily adjustable droop screws
  • Revised shock standoffs for easier droop measurement
  • New brake linkage for easier adjustments and more consistent braking
  • New revised 46t spur gear
  • New brake pads and discs for unparalleled durability and consistency
  • Longer rear sway bar for more consistent traction
  • Updated setup sheet for improved handling
Chassis:
  • Proven design
  • Optimized Narrow Chassis Layout with Adjustable Weight Distribution and Flex Characteristics
  • 4mm CNC 7075 aluminum hard anodized lightened chassis.
  • Class leading front and rear clearance (short chassis overhang) provides better bump handling and jump landing.
  • Integrated Radio Tray/Mud Guard for Unmatched COG, Lightness, and Durability
  • Adjustable, LCG lightweight wing mount.
  • Spacious, enclosed, easy access radio box with integrated transponder mount.
  • Adjustable chassis brace system for fine tuning flex with front, center, and rear braces.
Differentials and Drivetrain:
  • Innovative Rear Offset Differential Provides Minimal Drive Angles and Reduced Wear.
  • Lightened Drivetrain Components Throughout
