53HRA Posted April 17, 2015 Share Posted April 17, 2015 ? The Beast II is built with engineering and design first. Packed with great products like the R3 2 speed transmission, Yota II axles, Triton transfer case, Mil-Spec ZXL tires, and 1.9 Humvee beadlock wheels. There are no better options! Beast II... What's in store for you? Custom Designed for True to Scale Looks Realistic Aluminum Ladder Frame Chassis R3 Single Speed Transmission Center Mounted Realistic 4x4 Transfer Case Cast Metal Axles with Locked Differentials 3 Link front and 8 Link rear suspension Humvee 1.9 Internal Beadlock Wheel MIL-SPEC ZXL 1.9 Tires Chassis mounted Steering servo Dual Spring 80mm Scale Black Shocks Hammer Transfer Case: Ratio - 1:1 Gearing 32P hardened steel gears, 8 bearing Design, cast casingAll New R3 Scale 2 Speed Transmission: Ratios: Pinion/spur 14/64 =4.57:1 Internal 1.78:1 Gears - Wide steel 32P, Delrin spur, slipper clutchAll New Cast Yota II Axles: Ratio: 15/40 = 2.67:1 Width at hex 180.5mmBeast II Suspension: Double triangulated 8 Link rear suspension. 3 Link front suspension with panhard barShock Absorbers: Dual Spring 80mm Shocks - Can be oil filledWheels: Type: 1.9 Scale Beadlock Wheel Hub: 12mm Hex Width: 25mm Back spacing: 16mmBumpers: Machined billet aluminum, lightweight Beast II Dimensions: Wheels base F-R: 408mm(16.1 Quote Link to comment Share on other sites More sharing options...
