Bigjimknickers Posted March 27, 2015 Share Posted March 27, 2015 I've just put a new piston ring & gasket set on this engine I had laying about, question is, does the new ring need any break in period? Also, this is sold as a 30.5cc ported, so does that mean it has a +2 crank? Or is it bollocks & it's just a 29cc ported engine? (I need to know this as I've found a sweeeet head kit). Anyhow, I figured it out this engine in my Dbxl just for the crack it may be ok, it may be removed tomorrow, it's only a stop gap til I either source a new long block or a head kit for the CY23cc. Quote Link to comment Share on other sites More sharing options...
Titaniumrc Posted March 27, 2015 Share Posted March 27, 2015 New rings need bedding in, I fully run mine in like its a complete new engine. Many ways of braking in engines, every body has different ways. Sent from the I6 via talktapa Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted March 27, 2015 Share Posted March 27, 2015 I always assemble with a smear of 2 stroke oil, to help ease it in. Then just run it gently for a tank. Keep a close eye on the head bolts and exhaust bolts...as they can loosen off as the head settles in. I tend to keep to half/three quarters throttle for a tank, then go for it after I have given the bolts a check and tweak. I blew a brand new gasket after a top end overhaul after both head bolts slackened off when everything settled. I then discovered the plastic head shroud gets in the way...so I drill clearance holes in the plastic head cover over the head bolt holes. I don't bin the shroud, as it helps duct the cooling fan air over the head...but a few holes means I can check and access the head bolts 2 Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted March 27, 2015 Author Share Posted March 27, 2015 Ok, I'll go finish building it & give it a gentle test run. So I still can't find info on this KM 30.5 crank, weather its a normal or +2, anyone know? Quote Link to comment Share on other sites More sharing options...
John_RCModelz Posted March 27, 2015 Share Posted March 27, 2015 If it is the 30.5cc ported then it should have the 30mm Crank. If you are in you engine yo can have a look if it is the stuffed. Which engine did you order Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted March 27, 2015 Author Share Posted March 27, 2015 If it is the 30.5cc ported then it should have the 30mm Crank. If you are in you engine yo can have a look if it is the stuffed. Which engine did you order It was the one in the KM 002C that I bought in August 2014. Quote Link to comment Share on other sites More sharing options...
John_RCModelz Posted March 27, 2015 Share Posted March 27, 2015 That's not a 30.5 that is sold as a 29 ported Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted March 27, 2015 Author Share Posted March 27, 2015 Ahh ok, so I'll ignore the 30.5cc sticker! Good job I didn't order the piston kit for a +2 crank! Quote Link to comment Share on other sites More sharing options...
John_RCModelz Posted March 27, 2015 Share Posted March 27, 2015 Mr king motor thought that if you port the head and skim the piston it would make it a 30.5 without the need of a 30mm crank that's why there is a sticker on it. But we know better and made it clear in the listing The X2 is a 30.5 ported 1 Quote Link to comment Share on other sites More sharing options...
almighty15 Posted March 27, 2015 Share Posted March 27, 2015 Mr king motor thought that if you port the head and skim the piston it would make it a 30.5 without the need of a 30mm crank that's why there is a sticker on it. But we know better and made it clear in the listing The X2 is a 30.5 ported When did you update the site? I bought my C version purely because of the 30.5cc ported engine and now it does have it? It said 30.5cc engine when I bought my C..... That's crap... Quote Link to comment Share on other sites More sharing options...
flatout! Posted March 27, 2015 Share Posted March 27, 2015 I dont think you'd have noticed the difference thou matey, iv picked a stuffed stroker crank up for a Quote Link to comment Share on other sites More sharing options...
John_RCModelz Posted March 28, 2015 Share Posted March 28, 2015 When did you update the site? I bought my C version purely because of the 30.5cc ported engine and now it does have it? It said 30.5cc engine when I bought my C..... That's crap... The 002c has never said 30.5cc apart from on the pull start. It had reference to the item number (km 002c 30.5) but not cc and in the description it stated 29cc ported. When we purchased them they were meant to be standard 30.5cc (hence the title) but as above we discoved what they were when they was delivered and this was a couple of years ago. Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted March 28, 2015 Author Share Posted March 28, 2015 Soo, the KM top end is shot, lasted about 30mins, was difficult to start, then got slower & slower. Anyway. Decision time, buy a new engine or buy a top end kit, ie: http://www.freeprawnracing.co.uk/zenoah-4-bolt-36mm-29cc-top-end-kit-ca330.html Is that worth putting on A KM bottom end? Or jus add more & get a Cy long block? Quote Link to comment Share on other sites More sharing options...
almighty15 Posted March 30, 2015 Share Posted March 30, 2015 Get a lower displacement engine that has a high RPM, while the Baja is heavy it's not heavy enough to warrant a pure beats. A half decent, high revving engine would be well suited. Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted March 30, 2015 Author Share Posted March 30, 2015 I bought this last night: http://mmrmodeltech.com/opencart/index.php?route=product/product&product_id=60 Quote Link to comment Share on other sites More sharing options...
almighty15 Posted March 30, 2015 Share Posted March 30, 2015 Sexy! 1 Quote Link to comment Share on other sites More sharing options...
Bigjimknickers Posted March 30, 2015 Author Share Posted March 30, 2015 Get a lower displacement engine that has a high RPM, while the Baja is heavy it's not heavy enough to warrant a pure beats. A half decent, high revving engine would be well suited. This thread is about me putting an old KM engine in my Dbxl! Anyway, I gave up on the KM & bought a G290 MX longblock. Quote Link to comment Share on other sites More sharing options...
