chester-lad Posted March 6, 2015 Share Posted March 6, 2015 Hi all bought a new lrp .28 spec 3 for the savage all fitted went to start it pull start snaps knot that that was done was too small ..... So tried to sort it spent 2 hours fitting it back and spring pops out again ahhhh So im thinking fit a roto start but dont seem to be any in uk . Would a hpi one fit ? Quote Link to comment Share on other sites More sharing options...
RCbutcher Posted March 6, 2015 Share Posted March 6, 2015 I'm interested to know aswel. I have an lrp 32 and know the pull start will probably fail. Tiger drives I think are fairly universal you'll have to check. But hopefully someone posts a UK link to something compatible. Quote Link to comment Share on other sites More sharing options...
sean-vrs Posted March 6, 2015 Share Posted March 6, 2015 http://www.modelsport.co.uk/nitro-engine-starters/rc-car-categories/9930/993025&ManufacturerID=26 have a look here Quote Link to comment Share on other sites More sharing options...
chester-lad Posted March 7, 2015 Author Share Posted March 7, 2015 ^^ thanks for link . I see the roto start shaft looks the same as a hpi . So if i bought that i would be able to use a hpi starter ? Quote Link to comment Share on other sites More sharing options...
sean-vrs Posted March 7, 2015 Share Posted March 7, 2015 ^^ thanks for link . I see the roto start shaft looks the same as a hpi . So if i bought that i would be able to use a hpi starter ? i would ring modelsport to check Quote Link to comment Share on other sites More sharing options...
scrumpy jack Posted March 8, 2015 Share Posted March 8, 2015 Hi all bought a new lrp .28 spec 3 for the savage all fitted went to start it pull start snaps knot that that was done was too small ..... So tried to sort it spent 2 hours fitting it back and spring pops out again ahhhh So im thinking fit a roto start but dont seem to be any in uk . Would a hpi one fit ? Exactly the same thing happened on my brand new Z28 on the second pull- the knot was too small and pulled through- I brought some of that 'unbreakable' pull start cord off ebay and fitted it (with decent knots) and it's now fine, Luckily I managed to replace it without the spring popping out though. Quote Link to comment Share on other sites More sharing options...
chester-lad Posted March 8, 2015 Author Share Posted March 8, 2015 Will be taking it out later today to run it in so hope fully it dont break again ... for got about that unbreakable pull cord. May buy new pull start and fit that . Quote Link to comment Share on other sites More sharing options...
locky Posted March 8, 2015 Share Posted March 8, 2015 ^^ thanks for link . I see the roto start shaft looks the same as a hpi . So if i bought that i would be able to use a hpi starter ? Yes hpi rotostart shaft will fit into LRP rotostart backplate LRP38136, you dont need the LRP shaft. Quote Link to comment Share on other sites More sharing options...
chester-lad Posted March 8, 2015 Author Share Posted March 8, 2015 Thats good to know . Bloody pull start rope is digging in the housing ang getting caught up ... glow plug stick is crap too grrrr . . Good start to bashing day Quote Link to comment Share on other sites More sharing options...
chester-lad Posted March 8, 2015 Author Share Posted March 8, 2015 Well it snapped again its bisto for the pull start gravy all other ???? Quote Link to comment Share on other sites More sharing options...
chester-lad Posted March 10, 2015 Author Share Posted March 10, 2015 Little update turns out engine is faulty. Pull start no2 snapped had a look engine very hard to turn by hand but if i loosen the back plate for pull start it turns . Took pull start shaft out and it looks like something has been rubbing on the conrod ....[emoji22] Quote Link to comment Share on other sites More sharing options...
chester-lad Posted March 12, 2015 Author Share Posted March 12, 2015 New engine on its way [emoji3] Quote Link to comment Share on other sites More sharing options...
