Favorite eBay buys!
Nick
What's peoples favorite small / toolbox buys on eBay? Nuts, bolts, washers, tools, gadgets... those little things you find in other peoples toolboxes and keep getting told to buy your own?
Recommendations so far:
Tools
Iroda Gas Soldering Iron
Dremel Gas Soldering Iron
Digital Gauge Vernier
5.5mm Spanner
7mm Spanner
Shock Shaft Pliers
12v Mini Jump Starter
Lipo checker+alarm
Lipo Checker
Multi Wrench (Tamiya style - 4mm, 5mm, 5.5mm, 7mm)
Alternative digital Caliper
Consumables
Lead/Tin/Silver Solder
3:1 ratio black heat (adhesive)
Nuts and bolts
In the field repairs
Jaffa Tape
Cable ties
Edited by -BEZ-
links checked and good as of 14-9-15
Bez....you don;t need shock pliers. You can just use side cutters and a file ;)
My best E-Bay toolbox buy has to be my little flat multi spanner.... 4mm, 4.5mm, 5mm, 5.5mm, 7mm ... all those little nut and bolt sizes in one tiny handy sized flat tool. Takes up no space at all and I wouldn't go out without it.
Most useful multipack buy was buying a load of clutch shims and washers. It's a job where the spacer has to be the right size....and having a packet on hand is so useful.
Price has went up since end of last year. There are other types on the bay, but, ya need the 12v out option.
http://www.ebay.co.uk/itm/12V-Car-Portable-Jump-Starter-Booster-Power-Bank-Source-Pack-Mini-Battery-Charge-/111458992064?pt=LH_DefaultDomain_3&hash=item19f3793fc0
Nice, but notice how they warn you to disconnect in under thirty seconds! Basically, the cars alternator will quickly over-charge the lipo.
Still a neat gadget, far easier than firing up a second car, manoeuvring it into position etc.
I like it.
ive got side cutters and file, cool. il do some shock rebuild tonight :)
I like it.
I like this bit " Please remove the battery within  30 seconds after starting your car, or it may cause some accidents."...lol!!
I bought it because I'd parked the truck up when we had the dog out. Didn't notice I'd caught a switch gettin out , left 60" of Cree Lightbars running for an hour. Then had to wait an hour and a half in a Mamet coming out with jump leads.
Didn't do that again. :D
Edited by Philxj4L
  • 4 weeks later...
I need some new side cutters (smaller ones), any suggestions?
Preferably ones where the rubber handles dont spin around ......... thats rather annoying
what they like? Any good? Thats mega cheap
I needed to check if my Civic had a front 23 or 24 mm anti-roll bar.
got between 23.0 and 23.1 mm - case closed.
I expect them to be close but don't expect miracles at that price!
Work fine.
Al.
