raff113 Posted February 1, 2015 Share Posted February 1, 2015 hi guys picked an mini 8t yesterday as i wanted something to play with when my losi 5 is in hibernation , i was torn between the mini 8t or the merv so i went with cheaper option as both had sort of same reviews . Been out today with a 2s lipo and after five minutes i broke the rear hub didn't mind to much as i was freezing , so my Question is what parts are going to make it a solid basher , do mini 8ight parts fit on the T , I'm not to fussed about motor and esc or servo at the moment Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted February 1, 2015 Share Posted February 1, 2015 It's a fun truck but not really a basher diffs shocks and knuckles and hubs are the same the rest is different .. Mine was a blast but used to get through the spur gears quite quick Apart from the electrics being a pile of turd the dog bones are too soft and the diffs are quite weak you can shim the diffs which helps but the ring gear is to brittle and snaps off teeth easy . Real fun truck just too fragile for me . Quote Link to comment Share on other sites More sharing options...
