Momos Posted January 27, 2015 Share Posted January 27, 2015 I want to build a 6 wheel drive with clod axels needing some info how would I get esc's to work could I use 3 and one reciever and can I connect 3 servos together to run on one reciever not sure how to do it Quote Link to comment Share on other sites More sharing options...
DeadMeatUK Posted January 27, 2015 Share Posted January 27, 2015 You can run 3 ESC's off 1 receiver. What you need remember is to cut the red wire on 2 of the ESC's receiver plug so only one of them is powering the receiver and servos otherwise you will get awful glitching and worst case is blown ESC's. You can run 3 servos but should consider using a power cap and/or separate BEC as the BEC from one of the ESC may not be enough? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
DeadMeatUK Posted January 27, 2015 Share Posted January 27, 2015 How are you thinking of setting up three servos? If you do it wrong it will just crab steer! Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Momos Posted January 27, 2015 Author Share Posted January 27, 2015 I don't know how to set up servos I was going to axel mount them I need the front to go in different directions than back 4 is this right Quote Link to comment Share on other sites More sharing options...
