MAZ Posted December 19, 2014 Share Posted December 19, 2014 (edited) Is Stihl Ultra okay for my Baja engine? Its fully synthetic and designed for 2-stroke engines (I use it in my strimmer, blower, hedgecutter, combi unit) Some info on the oil:http://www.amazon.co.uk/Stihl-0781-319-8061-2-Stroke/dp/B007TJKGMWhttp://www.stihl.co.uk/STIHL-Products/Fuel-Oils-and-Canisters/Oils/21467-1559/HP-Ultra-two-stroke-engine-oil.aspxhttp://www.stihl.co.uk/stihl-hp-ultra-high-performance-engine-oil.aspx I'm wanting to clean out the baja's engine and then lube it up with the oil that I'll be using when I'm actually running the baja. Is it suitable though???! Cheers Edited December 19, 2014 by MAZ Quote Link to comment Share on other sites More sharing options...
MAZ Posted December 19, 2014 Author Share Posted December 19, 2014 I've had a fair few views on this but no replies as yet :/ I'm kinda thinking I'll just risk using it - I don't even know if the engine works - especially as there's a nick on the piston (right near the triangle) Could some grit have got in there and caused that?? Surely it couldn't make the engine run that terribly if I did use it?? *feeling lost* Quote Link to comment Share on other sites More sharing options...
sean-vrs Posted December 19, 2014 Share Posted December 19, 2014 the stihl oil will be fine Quote Link to comment Share on other sites More sharing options...
(-:AD:-) Posted December 19, 2014 Share Posted December 19, 2014 (edited) Yeah. Its good oil. Many people use it. The normal red stuff is good enough for a standard engine Edited December 19, 2014 by (-:AD:-) Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted December 19, 2014 Share Posted December 19, 2014 (edited) I've had a fair few views on this but no replies as yet :/ I'm kinda thinking I'll just risk using it - I don't even know if the engine works - especially as there's a nick on the piston (right near the triangle) Could some grit have got in there and caused that?? Surely it couldn't make the engine run that terribly if I did use it?? *feeling lost* i would`nt risk using it you can pick up a new piston pretty cheap heres a full kit including new bearings and other stuff they also do other cc sizes http://www.innovative-rc.com/23cc-piston-rebuild-32mm-p-547.html?osCsid=33a74c7f4e2691ec05d9b569939b40b8 Edited December 19, 2014 by mini-z-awd Quote Link to comment Share on other sites More sharing options...
mark35 Posted December 20, 2014 Share Posted December 20, 2014 It looks abit grubby in the bottom end there maz, Could do with a clean an rebuild. if you have a flywheel puller its quite easy. Do you fancy abit of home porting? An easy mod is to take 3mm from the inlet side of the piston skirt (opposite side of arrow) I've done this using a hand file. Check this link out....... http://www.baja-forum.co.uk/showthread.php?30975-Stock-26cc-rebuild-gt-29cc-Full-mod&highlight=piston Quote Link to comment Share on other sites More sharing options...
MAZ Posted December 20, 2014 Author Share Posted December 20, 2014 i would`nt risk using it you can pick up a new piston pretty cheap heres a full kit including new bearings and other stuff they also do other cc sizes http://www.innovative-rc.com/23cc-piston-rebuild-32mm-p-547.html?osCsid=33a74c7f4e2691ec05d9b569939b40b8 Cheers for that It looks abit grubby in the bottom end there maz, Could do with a clean an rebuild. if you have a flywheel puller its quite easy. Do you fancy abit of home porting? An easy mod is to take 3mm from the inlet side of the piston skirt (opposite side of arrow) I've done this using a hand file. Check this link out.......http://www.baja-forum.co.uk/showthread.php?30975-Stock-26cc-rebuild-gt-29cc-Full-mod&highlight=piston I am totally not feeling brave enough to attempt something like that yet lol Rebuilding a 2-stroke engine is a first for me as it is so I'll be happy with just getting the thing running before attempting any mods The engine is a bit grubby and I am in the process of doing a rebuild on it - just needed to get some oil sorted for it (can check that off the list now ) Looks like I'll have to order a few bits after christmas now though :/ Quote Link to comment Share on other sites More sharing options...
