nr73 Posted November 26, 2014 Share Posted November 26, 2014 Just finished making a few changes to my Slash 2wd. I really felt it was quite slow out of the box, and didn't have much torque at all, plus the tyres didn't give much grip on dirt. So I just fitted a turnigy 3520kv brushless with the 80a ESC. Also a set of Stampede wheels and tyres came up in the sales section a week ago so I picked those up, and they've helped give it the stance I was looking for. I've raised the body mounts to their highest position, might run into clearance issues but I'll see how it goes and raise it some more if I need to. I was disappointed that the steering endpoints aren't adjustable on the TQ radio, they could do with being reduced ever so slightly but I'll manage. Also the motor mount is a bit of a faff, and the ESC being raised up on some edged fins is a problem when you need to fix a replacement ESC down with some sticky pads. I've left it on the 16t pinion for now because I only have a 23t, and coupled with the tyres that could be a bit too tall. I've just given it a quick run on 2s and blimey what a difference. It now picks up it's skirt and shifts nicely! Quote Link to comment Share on other sites More sharing options...
bertberr Posted November 27, 2014 Share Posted November 27, 2014 Looking good... I think bigger MT style wheels/tyres make for a better general purpose basher and jumper. I fitted 2.8 badlands to my Torment SCT and I much prefer it for bmx / skate park duty. Think you'll find the stock pinion is 19 not 16t, with a 90t spur, 23 pinion and 86 spur come in bag. My torment came stock on 24/87 with a 3300kv motor, which was fine with the SCT tyres but I put in a 19t shortly after moving to the bigger tyres, as it was running quite hot with the 24t. On the 19 it ran a lot cooler, think it could probably take a 21 or 22 without issue, so I guess you'd probably be ok with 21/90 on yours. See what the temp gun says. Quote Link to comment Share on other sites More sharing options...
nr73 Posted November 27, 2014 Author Share Posted November 27, 2014 It's definitely on a 16/90, but it did come with the additional 23/86 in the bag too. Must have been changed at some point before I bought it I guess. Quote Link to comment Share on other sites More sharing options...
