off-road FPV
Sam.Dzharov
Hello, I have an E-revo and I live in a big private park in Devon. I wanted to explore some of the woods around in my park. It's a private park and I can easily get a permission from the land-owner to use any kind of RC. So my question is -> what Frequency and how many mW should I use, I have some old 35mhz radios so I could use a 2.4ghz FPV.
I know the law states that I can only use 2.4ghz or 5.8ghz and up to 25mW or something like that, but all the topics/info that I read was relating to Flying so would it make a difference if I'm not airborne?
Thanks for the replies, I'm buying everything from HobbyKing and it doesn't matter from which warehouse, also I'm looking to spend
Tx/rx id go for a dx6 or 5 if you want a stick if not then a gt3b or c if wanted
As for the camera theyres not really a rc road laws is common sense and accept people privacy if these are adhered to i see no issues fella especially being on private propety
the UK can only use 5.8ghz  which is rubbish.  lol   i wish we could use the other ones as they are fantastic.    i have 5.8ghz on one of my quads and line of sight is ok  but when i fitted it to my car the distance dropped alot.  i think alot of people use boosters.
i remember seeing a test with the fatshark 25mw and the 600mw  and i think the difference was  about 25%     as for ground used   (all rules state air use)
Edited by turok007
i have never looked into 1.3ghz for ground use.     but you might want to boost your transmitter as well
from the net
The 1.3 Ghz band
The myth regarding 1.3GHz comes mostly from our American cousins, because, if they have a
Edited by turok007
the license part is vague.  lol    and you really need to find someone on the NET who has done a FPV car already  so it saves you time and money trying to get it to work.
Edited by turok007
Not sure it affects them all the same but the last quote I saw about 1.3ghz is that it "kicks the a$$ out of 2.4 radio gear"
If I had indeed have used my illegal 1.3 setup in my plane, I expect that what would have happened is that the vtx would have cut into the rx signal and control would have been lost. The plane would then have circled slowly until hitting the ground and dislodging a few non-essential parts, like the wings. As soon as the vtx was turned off, normal range would have resumed. For this reason I would have ordered a 1.3 low pass filter from china to cut out all frequencies above the required video channel. Admittedly if that had of happened, the vtx was probably only 10cm from the rx.  :whistling:
Yeah I thought FPV would be easy after getting the goggles working lol.
There is a chart somewhere (can't find the link) detailing what else uses different frequencies. I think 1.3 was mainly bad weather airport landing beacons and coastal radio so if I had used my 1.3 setup I figured it wouldn't be in bad weather and I live in the midlands.....
  • 3 months later...
This will help....
Video frequencies for FPV
As you look deeper into FPV flying you soon realise there are lots off different brands of equipment available and whats more lots of different frequencies open to buy.
The equipment available is for use world wide. But as with all countries the UK has only a select few that we can legally use, that are open to us.
Not only are there certain frequencies that we are legal to use but there are also constraints on what power levels we can transmit legally on as well. The transmission levels though are another subject entirely. In this article ill concentrate on frequencies only
So what frequencies can you get video equipment for :
900 Mhz
1.2 ghz
1.3 ghz
2.4 ghz
5.8 ghz
So whats the difference ?
The lower the frequency band, the larger the waveform produced. The larger the waveform the further it travels, the better it can get round or penetrate objects such as small buildings, trees and people.
So in that case the obvious choice is go out and buy 900mhz video equipment ? Not that easy I
POWER OUTPUT !!!!!!!
your limited to 25mw ( not megawatts thats milliwatts)
go over this limit and your breaking the law .dont matter if its land -air subsea etc etc its illegal
the reason why is because to transmit on a higher power output you MUST hold a RADIO LICENCE .
in other words you need to sit a Ham radio licence exam and pass it. ( let me tell you it aint easy for a start, but once gained you can run over 10w of power and more)
alpha -bravo - romeo -foxtrot - wiskey , you have to learn all these codes and know them off by heart.
its not just about opperating but other things to.
systems 1.3ghz - 2.4ghz - 5.8ghz - 800mhz 900mhz
the last two 800-900mhz are mobile phone bands, you CANNOT USE THEM IN UK !!!
best systems are UHF dragon and the likes, but these cost an arm and leg and use UHF frequencys
range is huge with these, 3 mile+ ( thats the radio control system )
a UHF VTX -VRX is gonna cost an arm and leg to. its specialist gear and commands a price tag to.
so basic your stuck to 2.4ghz - 5.8ghz
but using differnet setups and boosting the reciever can help a little. also going with purpose made to measure antennas
that are tuned to the wavelength your using. cloverleafs and patch antennas ( patch ants are a large flat antenna like a big square disc)
they are normally hooked to a servo set and track the signal , or are directed by manual tacking and following.
here your using a narrow powered beam to direct it to the tx location.
most ground stations do not run a cloverleaf, they will have a large footprint patch antenna hooked up on a long high reach pole
Edited by Tamiyacowboy
