boombox Posted October 23, 2014 Share Posted October 23, 2014 ive got a suspected blocked card in my trophy4.6, ive popped the carb off but, i have no idea how to get into it. Is it even possible? Quote Link to comment Share on other sites More sharing options...
jordanp Posted October 23, 2014 Share Posted October 23, 2014 flush everything in side with some clean fuel and check what comes out then try the engine again make sure you get into the fuel intake aswell with it Quote Link to comment Share on other sites More sharing options...
Anthoop Posted October 24, 2014 Share Posted October 24, 2014 ive got a suspected blocked card in my trophy4.6, ive popped the carb off but, i have no idea how to get into it. Is it even possible? http://www.hpiracing.com/assets/documents/instruction_manuals/111598-f46_v2-glb-m-v1.pdf Number 7 shows an exploded view of the carb...it should show you what will come off/out...to remove the slide you need to first remove the idle screw. Usually no need to fully strip a carb. for a blockage...as Jordan said a flush through with some fuel and a bit of blowing will usually clear it.....but it is all good learning. 2 Quote Link to comment Share on other sites More sharing options...
jordanp Posted October 24, 2014 Share Posted October 24, 2014 thinicky buggers carbs......but there all good when they do there job Quote Link to comment Share on other sites More sharing options...
boombox Posted October 24, 2014 Author Share Posted October 24, 2014 Thanks for the help guys, ill try it tomorrow Quote Link to comment Share on other sites More sharing options...
