turtletom100 Posted September 19, 2014 Share Posted September 19, 2014 Hi there guys, Does anyone know what the park number for 5 he rubber grommets on the fuel 5 and mounting are or more to the point where I can purchase these from? Cheers tom Quote Link to comment Share on other sites More sharing options...
TrickyTris Posted September 19, 2014 Share Posted September 19, 2014 I think you have to buy a new fuel tank to get them as they don't sell them individually. I lost mine a long time ago and just replaced them with countersunk washers. There's no real need for them to be rubber, imo. Give these a go: http://www.hobbyking.co.uk/hobbyking/store/__23701__Black_Anodised_Aluminum_M3_Countersunk_Washer_8pcs_.html Quote Link to comment Share on other sites More sharing options...
Yoshimoto Posted September 19, 2014 Share Posted September 19, 2014 You can use std automotive grommets or short lengths of fuel line or O-rings if you want some vibration/abrasion resistance but foaming of the fuel via vibration shouldnt be an issue even without them. Yoshi 1 Quote Link to comment Share on other sites More sharing options...
turtletom100 Posted September 20, 2014 Author Share Posted September 20, 2014 I think you have to buy a new fuel tank to get them as they don't sell them individually. I lost mine a long time ago and just replaced them with countersunk washers. There's no real need for them to be rubber, imo. Give these a go: http://www.hobbyking.co.uk/hobbyking/store/__23701__Black_Anodised_Aluminum_M3_Countersunk_Washer_8pcs_.html Great that's why I couldn't find any lol I found grommets for other make cars. Cheers for the link but I would rather rubber not aluminium as I have a carbon top plate and wouldn't aluminium damage that? Quote Link to comment Share on other sites More sharing options...
turtletom100 Posted September 20, 2014 Author Share Posted September 20, 2014 You can use std automotive grommets or short lengths of fuel line or O-rings if you want some vibration/abrasion resistance but foaming of the fuel via vibration shouldnt be an issue even without them. Yoshi Cheers I will have a look for just grommets then. It weren't so much foaming but I seem to have tiny air bubbles in the fuel line. I'm not sure if this will affect the performance of the car. Quote Link to comment Share on other sites More sharing options...
Yoshimoto Posted September 20, 2014 Share Posted September 20, 2014 Well a couple of mine as supplied had such tight tank mounts that i doubt there was any dampening effect and i have not seen foaming or air in the fuel line-needless to say there shouldn't be bubbles in the fuel line really-If its still not starting and your seeing bubbles this could be minor bleed back from the carb but when running on the bench you shouldnt have bubbles-just check for any leaks-when you get the top deck off to do the grommets put the tank into water with the lines still fitted and check for air leaks by blowing through the lines while blocking the other line off-this should clarify the issue. You said that the lines have been replaced..make sure that they are not too large a internal diameter-the line should be a good snug fit on the nipples with no room to let air get dragged in. Yoshi Quote Link to comment Share on other sites More sharing options...
