Combo for Trophy buggy flux
RCpete
Ok guys, i want a new combo for the buggy flux. Can someone suggest something that will run nice and cool in my buggy, probably just gonna stay on 4s for now anyway. Any help will be much appreciated.
cheers.
What lipos are you planning to run?  4S 2000kv-2650kv, 5S 1700kv-1900kv 6S 1500kv- 1700v.  All depends on gearing and what surface the buggy is going to be run on everytime. Plus grip in the tyres and the right setup all comes into play with heat etc.
edit:  150a ESC is ideally suited but for 4S a 120a ESC is doable.
Edited by cyronn
I know I'm gona get stick for this but I don't see probs using the 80a esc if geared correctly. my son uses the rage in his rc8.2, a friend has it in his mugen and another friend had it in his rc8.2 before he sold it all making the 15 min mark on 4s running a fast track layout and not once have we had any issues with thermal or appearances from the magic genie. gear right for the occasion and jobs a good'un!
Probably on the limit there but there are 1/8th RTR models sold with 80A ESC's think Ansmann Virus did it.  That leaves no room though, I wouldn't recommend it
Edited by cyronn
Thanks for all the replys guys, i will be running on 4s to answer your question cyronn. Also the stock ESC in my trophy is also rated at 80amp, quite a few 1/8th rtr's come with them including the EB4 G3, virus and im sure one or two others. I must say i have had no problems. I was only going to replace it because i was gonna go for a slightly higher kv motor. Do you guys think the ESC could handle a higher kv motor, or should i just get a new one.
cheers.
